Your account is unblocked, please try now.
Thanks,
Tom
My problem is solved. But I want to understand why my account is blocked?
Thanks,
Anlei
Hi @wuanlei,
Some accounts get blocked due to too many unsuccessful login attempts. The system sees this as a brute-force attack and blocks the IP address for safety reasons.
Ok, I see.
@TomNVIDIA please check my account as well. I got the same issue although I did not try to login many times.
I have the team looking into your account now. I will update back here once I have information.
Best,
Tom
Your account is in good standing, can you please try again? If you still experience issues, please provide the exact steps that you are taking, browser version, OS, and geo where you are located.
@TomNVIDIA hi I’m trying to install doca with the sdkmanager from the command line but despite the connection working correctly I get this message: “failed to get configuration file from the server. Please check your network connectivity”
Hi @buciu,
Please start a new topic for your issue. You can find the DOCA forums here: DOCA - NVIDIA Developer Forums
