Hi
I downloaded the SDK Manager but when I got to Step 2. this error shows up;
Oops! Could not load NVIDIA SDK Details. Fail to get configuration file from server. please check your network connectivity.
My network is fine. my location is in Malaysia if that is helpful…
UPDATE:[u][/u]
Just addedthe zip file as requested nvsdkm.zip (1010 KB)
I have the same issue, and it says:
“You are trying to access content which is under NDA , please login with your developer site credentials If you still have problems and you believe you should have access- please contact kvadrevu@nvidia.com for further information.”
However I am logged in
Team, I am still getting the same issue in step 02 installation.
“Could not load the NVIDIA SDK details. Failed to get configuration file from the server. Please check your network connectivity.”
Tried downloading Jetpack 4.3 or 4.4 for Tx2
