Product Configurator - small bug after generating the data structure
In the product configuration utilities, there’s a small bug after generating the data structure. If you follow the normal workflow the variants will not update when selecting them in the Panel or after generating the no code UI. The issue stems from a checkbox not being ticked in the “Set Variant Selection” node in the graphs that are generated. There is a checkbox called “Set Variant” that needs to be ticked for it to work properly.
This is a small issue but can be an annoyance when you have many variants. You need to go into each graph and tick the box which can take some time. Also, for folks new to the product configuration tools, they’ll run into issues when following the tutorial series on the Youtube channel. It would be great if someone could resolve this in the next update.
Thanks for letting me know. I will pass this along.
