I have two Xavier in the following way: #1 Has the oldest jetpack version #2 Has the newest jetpack version
I’m trying to execute kernels concurrently using streams and in order to visualize it, my intention was to use NVVP from an external point and do remote profiling. The problem arise when this doesn’t work at Xavier#2 but it does at Xavier #1. The error is the following:
“Data collection for 1 analysis stages failed
Metric 22741001 not found
Metric 22741001 not found”
If I try to by profiling with NVPROF and then importing the result file, I get a serialized execution at Xavier#2.
The mentioned error also happens when executing kernels that do not use concurrent kernels. It also happens that the timeline for functions such as cudaMemcpy do not appear.
I do access as root to the remote device.
The older jetpack version is 4.1.1 Developer Preview and the jetpack version in the other AGX Xavier is 4.2.3
P.S: Sorry for the incorrect post title, I already changed it.
In order to reproduce this issue in our environment, could you share reproducible source code with us?
It can be a simple kernel or just a CUDA sample that can reproduce this issue.
