Hi! all,
I try to combine MapNet and PathNet in one program, and I make my program by coping code from demo landmarkdetection and pathperception and then doing some modified. But I found that my programm will be frozened when it finish iniliaze MapNet and PathNet. There were no error, the program is still running, but not go to next step.
Here is some snippt of my code:
int main(int argc, char* argv[]){
DetectorApp app;
app.onInitialize();
app.onProcess();
app.onRelease();
// initialize MapNet detector
// Initialize MapNet network
dwMapNetParams mapNetParams{};
CHECK_DW_ERROR(dwMapNet_initDefaultParams(&mapNetParams));
mapNetParams.networkPrecision = DW_PRECISION_FP32;
mapNetParams.networkModel = DW_MAPNET_MODEL_FRONT_MULTI_CLASS;
CHECK_DW_ERROR(dwMapNet_initialize(&m_mapNet, &mapNetParams, m_sdk));
// Initialize LandmarkDetector from MapNet
dwLandmarkDetectorParams landmarkParams{};
dwLandmarkDetector_initializeDefaultParams(&landmarkParams);
CHECK_DW_ERROR(dwLandmarkDetector_initializeFromMapNet(
&m_landmarkDetector, m_mapNet, landmarkParams, m_imageWidth,
m_imageHeight, m_sdk));
CHECK_DW_ERROR(dwLandmarkDetector_setCUDAStream(
m_cudaStream, DW_LANDMARK_TYPE_LANE_MARKINGS, m_landmarkDetector));
// Get threshold from command line
float32_t threshold;
try {
spdlog::info("The landmark network threadshold is" +
std::to_string(FLAGS_landmark_network_threadshold));
threshold = FLAGS_landmark_network_threadshold;
} catch (...) {
std::cerr << "Given threshold cannot be parsed." << std::endl;
return false;
CHECK_DW_ERROR(dwLandmarkDetector_setDetectionThreshold(
threshold, DW_LANDMARK_TYPE_LANE_MARKINGS, m_landmarkDetector));
threshold, DW_LANDMARK_TYPE_POLES, m_landmarkDetector));
spdlog::info("MapNet Initialized!");
// Initialize PathNet.
dwPathNetParams pathNetParams{};
CHECK_DW_ERROR(dwPathNet_initDefaultParams(&pathNetParams));
CHECK_DW_ERROR(dwPathNet_initialize(&m_pathNet, &pathNetParams, m_sdk));
// Initialize PathDetector.
// dwImageProperties imageProperties = camera->getOutputProperties();
CHECK_DW_ERROR(dwPathDetector_initializeFromPathNetWithCameraRig(
&m_pathDetector, m_pathNet, m_imageWidth, m_imageHeight,
m_calibratedCam, m_transformation, m_cudaStream, m_sdk));
// Set detection threshold.
float32_t detectionThreshold = FLAGS_pathnet_threadhold;
if (detectionThreshold < 0.0f || detectionThreshold > 1.0f) {
spdlog::warn("[PathDetectorApp]: Wrong detection threshold value. The "
"threshold is expected to be between 0 and 1. "
"Detection threshold is set to 0.5.");
detectionThreshold = 0.5f;
dwPathDetector_setDetectionThreshold(detectionThreshold, m_pathDetector);
// Set temporal smoothing factor.
float32_t temporalSmoothingFactor = FLAGS_temporal_smoothing_factor;
if (temporalSmoothingFactor < 0.0f || temporalSmoothingFactor > 1.0f) {
spdlog::warn("[PathDetectorApp]: Wrong temporal smoothing factor "
"value. The factor is expected to be between 0 and 1. "
"Temporal smoothing threshold is set to 0.1.");
temporalSmoothingFactor = 0.1f;
dwPathDetector_setTemporalSmoothingFactor(temporalSmoothingFactor,
m_pathDetector);
// Set look ahead distance.
float32_t lookAheadDistance = FLAGS_look_ahead_distance;
dwPathDetector_setMaxLookAheadDistance(lookAheadDistance, m_pathDetector);
// Set detection ROI.
int32_t roiX = FLAGS_roi_x;
int32_t roiY = FLAGS_roi_y;
int32_t roiWidth = FLAGS_roi_width;
int32_t roiHeight = FLAGS_roi_height;
int32_t imageWidth = static_cast<int32_t>(FLAGS_width);
int32_t imageHeight = static_cast<int32_t>(FLAGS_height);
if (roiX < 0 || roiX > imageWidth) {
spdlog::warn("[PathDetectorApp]: Incorrect values for roi.x. It should "
"be between 0 and imageWidth."
"roi.x is set to 0.");
roiX = 0;
if (roiY < 0 || roiY > imageHeight) {
spdlog::warn("[PathDetectorApp]: Incorrect values for roi.y. It should "
"be between 0 and imageHeight."
"roi.y is set to 0.");
roiY = 0;
if (roiX + roiWidth < 0 || roiX + roiWidth > imageWidth) {
spdlog::warn("[PathDetectorApp]: Incorrect values for roi.width."
"roi.width is set to imageWidth - roi.x.");
roiWidth = imageWidth - roiX;
if (roiY + roiHeight < 0 || roiY + roiHeight > imageHeight) {
spdlog::warn("[PathDetectorApp]: Incorrect values for roi.height."
"roi.height is set to imageHeight - roi.y.");
roiHeight = imageHeight - roiY;
dwRect detectionROI{roiX, roiY, roiWidth, roiHeight};
CHECK_DW_ERROR(dwPathDetector_setDetectionROI(&detectionROI, m_pathDetector));
spdlog::info("PathNet initialized!");
spdlog::info("Init successful!");
return true;
