Programming Suggestion for my custom board using Dual SOMs(AGX, NX)
I’m using two SOMs which are AGX 64GB and NX16GB ,with a single USB C 3.2 connector for communication and programming . How can i flash both of them using the same USB C, I’m open to suggestions. Thank you.
How did you design your custom board for this? I think you should clarify because you are doing something that seems no one ever did before.
We are designing a custom carrier board using two SOM modules: one AGX 64GB and one NX 16GB.
I am planning to flash the software using a single USB-C connector. We are considering using a MUX to select which SOM the USB-C connection is routed to.
The requirement is to use the same USB-C connector to flash the software onto either the AGX or NX SOM, depending on the MUX selection.
Will this approach work? If so, could you please suggest the recommended MUX configuration and any important hardware considerations for USB, power, and recovery mode?
There is no such design in any Jetson before. So nothing I could comment on this.
IMO, you need to make sure that MUX is always in correct status during the whole flash process. That is, from the host PC point of view, it just takes your device as single Jetson SOM.
It does not care how many SOMs are on your board. It is still a one to one flash to our flash tool.
