About Jetson AGX Xavier USB problem?
1.Can Jetson AGX Xavier flash only use USB port 0?
2.Can USB port 0 be changed to host?
3.Can USB port 0 use host & flash both?
  1. Flash a board does not require software configuration. There is no OS running when the board is getting flashed.
Thus, if the hardware design is correct, then it could be flashed. But only on USB0.
2.3 If you are asking about the kernel, then yes, it could be configured as otg. Also, AGX devkit is already this design…
