Python example
I can’t find/run
./python.sh python_samples/syntheticdata/basic/visualize_groundtruth.py
in this example: Python example.
Is there a change in the new Isaac version? I installed Isaac according to the instructions and added the Sample Asset.
Are there any additional steps needed to run the python examples?
Thank you and best regards
Hi @fgrander
If you are using a local machine, the python_samples folder and the python.sh is located in ~/.local/share/ov/pkg/isaac_sim-2021.1.1. If you are using docker on a remote workstation, the path is /isaac-sim
Open a terminal at this location and run the script from there :)
