Hey all,
I’m just getting started with CUDA SDK (like minutes ago) and am having difficulty running the “simpleTexture” project that’s included. I have a Quadro FX 3450 card, and it mentions in the CUDA_SDK_release_notes_win32.txt file that:
…The release and debug configurations require a GeForce 8800 Series GPU
(or equivalent Quadro GPU) to run properly.
- The emurelease and emudebug configurations run in device emulation mode,
and therefore do not require a GeForce 8800 Series GPU to run properly…
I can run the EMU versions, but not the standard DEBUG and RELEASE. The question is, shouldn’t I be able to use the standard versions? For this particular project, it reads in a pgm image file and outputs it again. When I use the standard RELEASE, the image that it writes out is completely black; however, it works properly (outputs the image again) if I use EMURELEASE. If anyone can tell me if this is most likely a software issue or if it a result of my particular graphics card, it’d be appreciated.
- CUDA-newbie
