Quadruped robot is not moving properly
Hi all,
I am trying to program a quadruped robot (similar to the Mini Cheetah), and trying to get it to run forward, backward, and rotate it left and right on the spot. I am publishing the angles of the joints via ROS and into Isaac Sim via a joint state.
Although I am able to move the robot, I am experiencing a few problems with the gait of the robot:
  1. The on-the-spot rotation is slow, possibly due to the feet sliding and legs not ‘anchoring’ to the ground.
  2. Possibly for the same reason, its backward motion is slower than its forward motion, and not in a straight line, possibly for the same reason. It slightly lifts its hind legs up the air.
  3. The transition between different states (moving/not moving/rotation) is not smooth as the angles I am sending out to the robot are very different from each other between states.
Code
import rospy
from sensor_msgs.msg import JointState
import numpy as np
import time
import sys, select, termios, tty
from math import radians
rospy.init_node("mini_cheetah_bridge",anonymous=True)
pub = rospy.Publisher("/joint_command",JointState, queue_size=10)
joint_state = JointState()
joint_state.name = [
    "lf_upper_leg_joint",
    "lf_lower_leg_joint",
    "lh_upper_leg_joint",
    "lh_lower_leg_joint",
    "rf_upper_leg_joint",
    "rf_lower_leg_joint",
    "rh_upper_leg_joint",
    "rh_lower_leg_joint",
    "lf_hip_joint",
    "lh_hip_joint",
    "rf_hip_joint",
    "rh_hip_joint"
num_joints = len(joint_state.name)
crouch_angle = radians(45)  #initial angle of hip joint (in radians)
velocity = 10 #how fast the robot is moving
joint_state.position = np.array([crouch_angle,-2*crouch_angle,
    crouch_angle,-2*crouch_angle, 0, 0, 0, 0])
joint_state_default = joint_state.position
#print(joint_state.position)
#WALKING VARIABLES
normalized_leg_time = 0.8 #time that hip and leg change angle to lift leg (portion in walk cycle, 0 = beginning and 1 = end)
velocity = 2 #velocity feature not done yet - SHOULD BE KEPT AT 1
cycle_time = float(1/velocity)
print("Cycle Time:", cycle_time)
max_ul_angle = 60
min_ul_angle = 15
max_ll_angle = -90
min_ll_angle = -120
normalized_leg_turn_time = 0.5
max_hip_turn_angle = 5
min_hip_turn_angle = -5
max_ul_turn_angle = 60
min_ul_turn_angle = 45
max_ll_turn_angle = -90
min_ll_turn_angle = -120 #-135
rate = rospy.Rate(20)
joint_state.velocity = np.zeros([num_joints])
joint_state.effort = np.zeros([num_joints])
#print(joint_state.velocity)
def get_walking_pattern(x, dir, move_as_pace=False):
    hip_pattern1 = hip_pattern2 = 0
    u_leg_pattern1 = u_leg_pattern2 = crouch_angle
    l_leg_pattern1 = l_leg_pattern2 = -2*crouch_angle
    lift_leg_time = normalized_leg_time/velocity
    lift_leg_turn_time = normalized_leg_turn_time/velocity
    x_other = x + 0.5/velocity
    if dir == "forward":
        if x % cycle_time < lift_leg_time:
            u_leg_pattern1 = (radians(max_ul_angle - min_ul_angle)/lift_leg_time)*(x % cycle_time) + radians(min_ul_angle)
            l_leg_pattern1 = radians(-90) #((np.pi/6)/lift_leg_time)*(x % 1) + radians(-90)
        elif x % cycle_time < cycle_time - (cycle_time - lift_leg_time)/2:
            u_leg_pattern1 = (-radians(max_ul_angle - min_ul_angle)/(cycle_time - lift_leg_time))*(x % cycle_time) + radians(240)
            l_leg_pattern1 = (-radians(max_ll_angle - min_ll_angle)/((cycle_time - lift_leg_time)/2))*(x % cycle_time) + radians(150)
        else:
            l_leg_pattern1 = (radians(max_ll_angle - min_ll_angle)/((cycle_time - lift_leg_time)/2))*(x % cycle_time) + radians(-390)
        #print("U Leg pattern 1:",u_leg_pattern1)
        #print("\r")
        #print("L Leg pattern 1:",l_leg_pattern1)
        #print("\r")
        if x_other % cycle_time < lift_leg_time:
            u_leg_pattern2 = (radians(max_ul_angle - min_ul_angle)/lift_leg_time)*(x_other % cycle_time) + radians(min_ul_angle)
            l_leg_pattern2 = radians(-90) #((np.pi/6)/lift_leg_time)*(x_other % 1) + radians(-90)
        elif x_other % cycle_time < cycle_time - (cycle_time - lift_leg_time)/2:
            u_leg_pattern2 = (-radians(max_ul_angle - min_ul_angle)/(cycle_time - lift_leg_time))*(x_other % cycle_time) + radians(240)
            l_leg_pattern2 = (-radians(max_ll_angle - min_ll_angle)/((cycle_time - lift_leg_time)/2))*(x_other % cycle_time) + radians(150)
        else:
            l_leg_pattern2 = (radians(max_ll_angle - min_ll_angle)/((cycle_time - lift_leg_time)/2))*(x_other % cycle_time) + radians(-390)
        #print("U Leg pattern 2:",u_leg_pattern2)
        #print("\r")
        #print("L Leg pattern 2:",l_leg_pattern2)
        #print("\r")
    elif dir == "left":
        if x % cycle_time < lift_leg_turn_time:
            hip_pattern1 = (-radians(max_hip_turn_angle - min_hip_turn_angle)/lift_leg_turn_time)*(x % cycle_time) + radians(max_hip_turn_angle)
            hip_pattern2 = (radians(max_hip_turn_angle - min_hip_turn_angle)/lift_leg_turn_time)*(x % cycle_time) - radians(max_hip_turn_angle)
            u_leg_pattern1 = radians(min_ul_turn_angle)
            l_leg_pattern1 = radians(-90) #-radians(max_ll_turn_angle - min_ll_turn_angle)/(lift_leg_turn_time/2)*(x % cycle_time) + radians(max_ll_turn_angle)
        elif x % cycle_time < 1.5*lift_leg_turn_time:
            hip_pattern1 = (radians(max_hip_turn_angle - min_hip_turn_angle)/lift_leg_turn_time)*(x % cycle_time) + radians(-10)
            hip_pattern2 = (-radians(max_hip_turn_angle - min_hip_turn_angle)/lift_leg_turn_time)*(x % cycle_time) - radians(-10)
            u_leg_pattern1 = radians(max_ul_turn_angle - min_ul_turn_angle)/(lift_leg_turn_time/2)*(x % cycle_time) + radians(15)
            l_leg_pattern1 = -radians(max_ll_turn_angle - min_ll_turn_angle)/((cycle_time - lift_leg_turn_time)/2)*(x % cycle_time) + radians(-30)
        else:
            hip_pattern1 = (radians(max_hip_turn_angle - min_hip_turn_angle)/(cycle_time - lift_leg_turn_time))*(x % cycle_time) + radians(-10)
            hip_pattern2 = (-radians(max_hip_turn_angle - min_hip_turn_angle)/(cycle_time - lift_leg_turn_time))*(x % cycle_time) - radians(-10)
            u_leg_pattern1 = -radians(max_ul_turn_angle - min_ul_turn_angle)/(lift_leg_turn_time/2)*(x % cycle_time) + radians(105)
            l_leg_pattern1 = radians(max_ll_turn_angle - min_ll_turn_angle)/(lift_leg_turn_time/2)*(x % cycle_time) + radians(-210)
        if x_other % cycle_time < lift_leg_turn_time:
            u_leg_pattern2 = radians(min_ul_turn_angle)
            l_leg_pattern2 = radians(-90) #-radians(max_ll_turn_angle - min_ll_turn_angle)/(lift_leg_turn_time/2)*(x_other % cycle_time) + radians(max_ll_turn_angle)
        elif x_other % cycle_time < 1.5*lift_leg_turn_time:
            u_leg_pattern2 = radians(max_ul_turn_angle - min_ul_turn_angle)/(lift_leg_turn_time/2)*(x_other % cycle_time) + radians(15)
            l_leg_pattern2 = -radians(max_ll_turn_angle - min_ll_turn_angle)/((cycle_time - lift_leg_turn_time)/2)*(x_other % cycle_time) + radians(-30)
        else:
            u_leg_pattern2 = -radians(max_ul_turn_angle - min_ul_turn_angle)/(lift_leg_turn_time/2)*(x_other % cycle_time) + radians(105)
            l_leg_pattern2 = radians(max_ll_turn_angle - min_ll_turn_angle)/(lift_leg_turn_time/2)*(x_other % cycle_time) + radians(-210)
    elif dir == "right":
        if x % cycle_time < lift_leg_turn_time/2:
            u_leg_pattern1 = radians(max_ul_turn_angle - min_ul_turn_angle)/(lift_leg_turn_time/2)*(x % cycle_time) + radians(min_ul_turn_angle)
            l_leg_pattern1 = -radians(max_ll_turn_angle - min_ll_turn_angle)/(lift_leg_turn_time/2)*(x % cycle_time) + radians(max_ll_turn_angle)
        elif x % cycle_time < lift_leg_turn_time:
            u_leg_pattern1 = -radians(max_ul_turn_angle - min_ul_turn_angle)/(lift_leg_turn_time/2)*(x % cycle_time) + radians(75)
            l_leg_pattern1 = radians(max_ll_turn_angle - min_ll_turn_angle)/((cycle_time - lift_leg_turn_time)/2)*(x % cycle_time) + radians(-150)
        else:
        if x_other % cycle_time < lift_leg_turn_time/2:
            l_leg_pattern2 = -radians(max_ll_turn_angle - min_ll_turn_angle)/(lift_leg_turn_time/2)*(x_other % cycle_time) + radians(max_ll_turn_angle)
            u_leg_pattern2 = radians(max_ul_turn_angle - min_ul_turn_angle)/(lift_leg_turn_time/2)*(x_other % cycle_time) + radians(min_ul_turn_angle)
        elif x_other % cycle_time < lift_leg_turn_time:
            l_leg_pattern2 = radians(max_ll_turn_angle - min_ll_turn_angle)/((cycle_time - lift_leg_turn_time)/2)*(x_other % cycle_time) + radians(-150)
            u_leg_pattern2 = -radians(max_ul_turn_angle - min_ul_turn_angle)/(lift_leg_turn_time/2)*(x_other % cycle_time) + radians(75)
        else:
    elif dir == "backward":
            u_leg_pattern1 = (-radians(max_ul_angle - min_ul_angle)/lift_leg_time)*(x % cycle_time) + radians(max_ul_angle)
            u_leg_pattern1 = (radians(max_ul_angle - min_ul_angle)/(cycle_time - lift_leg_time))*(x % cycle_time) + radians(-165)
        else:
            u_leg_pattern2 = (-radians(max_ul_angle - min_ul_angle)/lift_leg_time)*(x_other % cycle_time) + radians(max_ul_angle)
            u_leg_pattern2 = (radians(max_ul_angle - min_ul_angle)/(cycle_time - lift_leg_time))*(x_other % cycle_time) + radians(-165)
        else:
    if move_as_pace:
        return np.array([u_leg_pattern1, l_leg_pattern1, u_leg_pattern1, l_leg_pattern1,
                        u_leg_pattern2, l_leg_pattern2, u_leg_pattern2, l_leg_pattern2,
                        hip_pattern1, hip_pattern1, hip_pattern2, hip_pattern2]) #pace
    return np.array([u_leg_pattern1, l_leg_pattern1, u_leg_pattern2, l_leg_pattern2,
                     u_leg_pattern2, l_leg_pattern2, u_leg_pattern1, l_leg_pattern1,
                     hip_pattern1, hip_pattern1, hip_pattern2, hip_pattern2]) #trot
def getKey(): #reads keyboard input
    tty.setraw(sys.stdin.fileno())
    rlist, _, _ = select.select([sys.stdin], [], [], 0.1)
    if rlist:
        key = sys.stdin.read(1)
    else:
        key = ''
    termios.tcsetattr(sys.stdin, termios.TCSADRAIN, termios.tcgetattr(sys.stdin))
    return key
print("Use the WASD keys to control the robot.")
def control_cheetah():
    while not rospy.is_shutdown():
        key = getKey()
        key = key.lower()
        if key == 'q':
            print("Quitting program\r")
            break
        if key == 'w':
            #print("W")
            joint_state.position = get_walking_pattern(time.time(), "forward")
        elif key == 's':
            #print("S")
            joint_state.position = get_walking_pattern(time.time(), "backward")
        elif key == 'a':
            #print("A\r")
            joint_state.position = get_walking_pattern(time.time(), "left")
        elif key == 'd':
            #print("D\r")
            joint_state.position = get_walking_pattern(time.time(), "right")
        else:
            joint_state.position = joint_state_default
        pub.publish(joint_state)
        rate.sleep()
if __name__ == "__main__":
    control_cheetah()
(and on a minor note, when I run this code and exit the program , I can’t seem to type anything on the terminal and have to close it).
The reason why I am not implementing a full controller is because programming rotation and forward/backward movement is sufficient for my project, and I couldn’t find any controllers specifically for Isaac Sim (I am trying to see if there are controllers implemented for other programs that I can adapt to Isaac Sim, but with no success so far).
Would like to know what I could do now, thanks.
I am having the same issue you are describing. Any inisght would be greatly appreciated!
Hi!
Can you please confirm that you have reviewed this document and still having the issues: Quadruped — Omniverse Robotics documentation
