Question about PCIe controller # mapping.
In Jetson_AGX_Orin_Series_Design_Guide_DG-10653-001_v1.2.pdf, “PCIe output Reference clock for controller #xxx” is described.
How can I match PCIe vs PCIe controller #xxx?
Where can I refer to the document that described this?
Below “Table 7-12.” of Design Guide page 43, in “Usage/Description” example listed as “PCI output Reference Clock for controller”, how can I match Controller #0 to #10 of PCIe (UPHY_TXxx_P/N)?
For example, If I want to use four (4) PCIe then also what PCIe Reference clock should I select and use for these PCIe signals?
Thank you for your description.
Other questions are as follows.
Q1
---- As your mentioned Table 7-4 listed (C0), (C1), C4), (C5), and (C7). Does it mean Controller #0, 1, 4, 5, 7 of blocks 0, 1, 2?
Q2
---- In the case of MGBE (C0) for UPHY_RX6/TX6 is used for 10G with the “Configuration #1”, and other UPHY2 Lane0~3, and Lane 5~7 can be used PCIe x8 “Configuration #2” mode is possible?
---- Can I have another controller # not mentioned in Table 7-2 mapping with PCIe or other matching signals that are listed in Table 7-12 and Table 7-13.? (C6, C8, C10)
---- Because I will use several PCIe in the new design Carrier Board.
---- I want to design four(4) PCIe lanes instead of implementing a PCIe connector that assigned Lane 0 ~ 7 of UPHY1. (for 4 PCI to 4 Giga Ethernet)
---- Q1
The Dev. Kit has a PICe connector involving x16 by using only one reference clock (PCIE5_CLK_P/N), but if I use another four(4) PCIe interface chips (PCIe to Ethernet controller) instead of the PCIe connector by using PCIe lanes of this connector connected, should I add Reference clock distributor buffer chip (ex: PI6CB33602) for the PLL FAN buffer out to four each four PCIe to Ethernet controller chips?
