RAW16 Stereo sensor LibArgus
I’d like to use 2 sensors in one CaptureSession, so they share the same AutoExposure values. This is working with using PIXEL_FMT_YCbCr_420_888 format. But changing to PIXEL_FMT_RAW16 I cannot get frames from Argus Stream whenever there are more than one camera added to the capture session.
I found this github page, which had the same problem.
At the time of writing this, Libargus only supports the PIXEL_FMT_YCbCr_420_888 and selectively supports PIXEL_FMT_RAW16 for certain configurations (Multiple camera capture sessions are NOT supported for now).
Do you plan on supporting this? Is there an easy patch I could implement, that fixes this? It is a much-needed feature for our company. Do you see any workarounds?
Best regards,
jb
Don’t have plan for it now.
Too bad, we have to implement our own AutoExposure algorithm then.
Thanks for the clarification, anyway! :)
