Hello all,
So I usually use Advanced Skeleton for all my rigging but I’m wondering if theres a better recommendation for maximum compatibility with Omniverse.
Thanks,
Dan Rita
Hello all,
Thanks,
Dan Rita
Hi @Dan.Rita!
Without seeing the structure of this particular rig tool, its hard to say if it is compatible or not. I brought your inquire to our character animation expert to get more insight.
The maya plugin has a guide (located here: Maya — Omniverse Connect documentation) discusses how a rig should be setup for export to USD.
There should be a single joint hierarchy under a skel root, then the skeleton and geometry grouped. Essentially, an export rig and a separate control rig.
