Red LED is flashing on CR5 and CR6. Is there any solution?
CR5 is VDD_IN LED and CR6 is PCIe/SATA 12V LED.
Do you mean these 2 LEDs are blinking?
Is there something wrong with your power?
Hello, JimWang,
I have similar issue, new Jetson TX1 just received, but it doesn’t power up.
CR5 and CR6 are red - not flashing, they just keep lighting up.
Two green lights next to the power button light up also, but there seems nothing happens - no display, no fan spinning at all, CAPs lock on keyboard doesn’t work either.
Do you have any advice?
CR5 and CR6 are single color LEDs, and the color is red, they are lighting up red just mean the power is on.
Two green lights next to the power button light up, these are CR1 and CR2, also single color LEDs, but the color is Green.
So it’s normal case when power on if these 4 LED lighting up.
