Removing Nvidia System Monitor
Hi everyone,
I downloaded Omniverse yesterday but after I did my rendered mode viewport stopped working in Blender. I tried to remove everything but I cannot find how to remove system monitor??? I can’t even stop it from starting upon booting my computer.
Does anyone have an answer for this? System monitor may not be the issue but I am trying all my options.
Have a great day,
Greg
Greg -
Sorry you are having issues with Blender.
You can temporarily stop the Omniverse system monitor by right clinking on its icon in icon tray. Then selecting “exit”
This will stop the system monitor, but a reboot will start it up again
To remove system monitor permanently:
  1. If you installed Nucleus, go to “Collaboration” and click on the stack icon to the right of “Local Nucleus Services” and select Uninstall.
  2. In the Launcher go to “Library”, click on “Cache” in File Management and perform the uninstall
You can always reinstall both cache and Nucleus at a later time. Cache first, then Nucleus
I will give that a try. I am going to reinstall Omniverse I just want to know if that is the issue. I also have 2 gpus in so if the system monitor is not the issue I will test that after.
Thank you very much!
There seems to be an issue with a port number clash between Blender rendering service <> Omniverse System Monitor. At the moment there is no way to change the port number used by system monitor.
This issue has been raised.
We will make a Port Configuration Tool,
And what if you didn’t install Nucleus? I installed Omniverse to see the marbles demo. When I was done, I uninstalled Omniverse. System Monitor is still here. Why doesn’t it get removed with Omniverse?
After some investigations, Omniverse Systeme Monitor is silently running as sheduled task and can’t be stopped (even if you are an admin, and even after many reboots), and even after uninstallation.
You have to remove it manually from scheduled tasks list, then reboot the computer. And then delete all associated files manually.
The default executable location seems to be C:\Users<username>\AppData\Local\ov
@keith.greene -
The following link provides a information and tool to remove Omniverse infrastructure. Future versions will prevent the need to run the cleanup tool to remove installed Omniverse processes
https://docs.omniverse.nvidia.com/prod_launcher/prod_utilities/cleanup-tool.html
