Hello @NandoC! Welcome to the Community! I sent your post to the the dev team. Can you send us your logs?
- Omniverse Logs:
C:\Users\<USERNAME>\.nvidia-omniverse\logs - Nucleus Logs:
%HOMEPATH%\.nvidia-omniverse\logs
Also, are you able to run the Omniverse System Monitor?
nucleuslogs.zip (154 Bytes)
New Compressed (zipped) Folder.zip (22 Bytes)
Hi Wendy I am able to run the Omniverse System Monitor but I can’t access to it as you can see in the picture, I changed the path of the cache app I don’t know if the problem comes from this reason. I notice that I am not able to connect to my server too so I don’t know what’s the problem.
Thank you @NandoC. The development team is reviewing your files.
Hello @NandoC! Can you upload your files again? The ones that are attached to this post have no data. Thanks!
nucleus-setup.zip (1.9 KB)
nucleus_logs.zip (7.1 MB)
logs.zip (10.6 MB)
Hi WendyGram sorry for the delay but I was trying to figure out what could happen and try to find the correct path to send you the logs. I hope this are the good ones. Thanks!
Thank you @NandoC. The dev team is reviewing your files.
