Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
Other (please specify):
GPU Information
- Model: T4
- Driver Version: 535.183.01
Calls to physx_cooking.request_convex_collision_representation()
fail with RESULT_ERROR_COOKING_FAILED
With the last major update I had to switch to the get_physx_cooking_interface()
( 296302 )
Now with the update to 4.5 I get errors.
I have attached the usda file I want to read the collider data from. (They are different from our old usda files because the URDF Importer has changed.) I have tried to calling request_convex_collision_representation()
on the collisions prim (the one that has the PhysicsCollisionAPI
) or the Flattened_Prototype_1
and many other variants. However, I was not able to retrieve the collider data yet.
exp_L.txt (36.1 KB)
@ AlesBorovicka
Could you maybe help me here again?
Hello, thank you for posting this issue. I am unable to reproduce the error on my side. If I run the ConvexMeshData example (Windows>Examples>Physics Examples), I am able to call
physx_cooking.request_convex_collision_representation(stage_id=stage_id,
collision_prim_id=prim_id,
run_asynchronously=False, # <-- Synchronous
on_result=self.on_convex_representation_ready)
And I get a callback after with PhysxCollisionRepresentationResult.RESULT_VALID
and the corresponding collider convexes.
Would you be able to share the code that you are running that causes the error?
Thank you for the reply.
I don’t use the GUI much and I don’t understand how I could load my usd files into this example. However, I’ve set up a minimal repro here.
repro.zip (13.8 KB)
Note: I figured out some sort of workaround by manually updating the imported usd to be non instanceable and then removing various APIs. With those exported usds I can use the request_convex_collision_representation()
. (See the comments in the repro code.)
Still I think there is a serious issue. How can you access the collider data of instanceable meshes?
Hi, the problem might be that you were not applying the CollisionAPI
and MeshCollisionAPI
to a mesh instance. In your repro case, you might want to apply them to prim at path /object/object/collision/exp_L/mesh
Here is a fixed script
repro.zip (3.8 KB)
I’ll go ahead and close the topic for now. Feel free to re-open if there are any additional issues.
