I have a complex USD files with lots of things inside, and set some of them with rigid body and collision. When I load the usd file, the terminal log shows lots of warnings as shown below:
After loading the scene, i clike the play button and the Isaacsim program get stucked, last log shows in the terminal is below:
2024-11-20 06:24:27 [340,816ms] [Warning] [carb.ujitsoagent.plugin] UJITSOAgent : node () hit hash collision. Data: MetaData different at pos: 48. Difference in metadata, this indicates that the meta data generation is non-deterministicor some option / input wasn’t included correctly in gatherDependencies.
2024-11-20 06:24:27 [340,816ms] [Warning] [carb.ujitsoagent.plugin] Difference in metaData
2024-11-20 06:24:28 [341,467ms] [Warning] [omni.physx.cooking.plugin] ConvexDecompositionCookingTask: adjusted the thickness of a very thin or very small mesh such that it meets the requirements for a GPU compatible convex hull collider. Prim
2024-11-20 06:24:28 [341,539ms] [Warning] [omni.physx.cooking.plugin] ConvexDecompositionCookingTask: adjusted the thickness of a very thin or very small mesh such that it meets the requirements for a GPU compatible convex hull collider. Prim
2024-11-20 06:32:53 [846,711ms] [Warning] [carb.ujitsoagent.plugin] UJITSO : Build storage validation failed for Storage status: 01
2024-11-20 06:32:53 [846,711ms] [Error] [omni.physx.cooking.plugin] m_processResult == OperationResult::SUCCESS is false.
I tried the Isaacsim 4.0.0, 4.1.0 and 4.2.0, all these three versions shows the same error and get stuck. Dose anyone knows how to fix this?
Isaac Sim Version
4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Isaac Lab Version (if applicable)
1.2
1.1
1.0
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model:
- Driver Version:
Topic Description
Detailed Description
(Describe the issue in detail, including what you were trying to do, what you expected to happen, and what actually happened)
Steps to Reproduce
(Add more steps as needed)
