Hi, I am trying to load in my custom robot in omniverse and use RMPflow to manipulate it and move it to a target. I got the robot from a CAD model and rigged its joints myself. They all work properly, and the robot does move, but not to the target. The cspace rmp seems to be the only one affecting the movements (when I set the cspace metric scalar to zero isaac sim hangs). The robot does not move to my target despite RMPflow getting the location of it properly. Since my robot arm is imported, I used the URDF exporter to create the URDF, and the franka robotic_description.ymal file to get some basic config (I messed around with this a lot though). Since the issue is likely my URDF, how can I validate or fix this?
Related topics
| Robot Manipulator does not reach target position RMP Flow | 3 | 259 | December 25, 2024 | |
| RMPflow Motion Generation | 4 | 732 | November 6, 2024 | |
| Custom Robot Arm not reaching target while using RMP Flow | Imprecise control of robotic arm | 12 | 1321 | October 5, 2023 | |
| Why is it that my robotic arm doesn't work properly with the rmpflow tracking algorithm, what could be the reason? | 2 | 175 | May 7, 2025 | |
| End-effector offset of RMP/IK | 22 | 2488 | November 8, 2022 | |
| Robot collision sphere moved from robot while using RMPflow | 8 | 1676 | October 27, 2023 | |
| After the RmpFlow exceeds a certain position range, the end following task is not accurate | 1 | 302 | May 6, 2024 | |
| RMP on my own robot (omni.isaac.motion_planning: RMP Extension) | 4 | 745 | October 29, 2021 | |
| Using RMPflow controller can not make the manipulator reach the specified position accurately, and there is always a slight deviation | 0 | 193 | November 26, 2024 | |
| Bug from follow_target_with_rmpflow.py | 1 | 178 | August 10, 2024 |
