Hi…
I’m getting trouble to run the Shuffle Box with Simulator sample under the system shown in the image…
I have a “full contained in containers” remote workstation and I think that the problems are int the IP/PORT configuration of the Robot Engine Bridge connection…
These are the current configuration that I have running:
Isaac Sim (Robot Engine Bridge - application json)
/isaac-sim/_build/linux-x86_64/release/exts/omni.isaac.robot_engine_bridge/resources/isaac_engine/json/isaacsim.app.json
"config": {
"interface": {
"input": {
"port": 55001,
"host": "0.0.0.0"
"output": {
"port": 55000
Isaac SDK (sim tsubgraph for tcp connection: loaded by apps/samples/manipulation/shuffle_box.py in the line 131)
packages/navsim/apps/navsim_tcp.subgraph.json where the host is the Remote Workstation IP
"config": {
"interface": {
"input": {
"port": 55001
"output": {
"port": 55000,
"host": "172.17.6.97"
When I open the stage at omni:/Isaac/Samples/Isaac_SDK/Scenario/sortbot_sim.usd and start the simulation and the Robot Engine Bridge; and I run bazel run apps/samples/manipulation:shuffle_box there is a partial connection between the applications. I can see the stage CAD model from Isaac Sight but it doesn’t work.
Also, these are segments of the “continuous logs” of both applications:
Isaac Sim
2020-07-27 09:34:05.323 WARN engine/alice/components/TcpSubscriber.cpp@165: Failed to connect to remote. Will try again in 0.500000 seconds.
Isaac SDK
2020-07-27 09:35:34.795 WARN engine/alice/components/TcpSubscriber.cpp@191: EOF encountered which likely indicates that the connection was closed by the remote. Will try to reconnect.
2020-07-27 09:35:34.795 INFO engine/alice/components/TcpSubscriber.cpp@140: TCP receiver trying to connect to remote (172.17.6.97:55000)...
2020-07-27 09:35:34.795 INFO engine/alice/components/TcpSubscriber.cpp@170: Successfully connected to remote (172.17.6.97:55000). Will start receiving.
In summary:
- WHAT WOULD BE THE CORRECT CONFIGURATION TO LINK BOTH APPLICATIONS IN A FULLY CONTAINED ENVIRONMENT?
- WHAT APPLICATION MUST BE EXPORT THE PORTS TO THE HOST AND ACT AS A SERVER?
Thanks in advance
