As the ros part has changed to sim 2022.1, the action graph must now be used.
Now, I brought the urdf we made to sim and confirmed that Lidar and Camera are well seen as Ros rviz.
However, the driving section cmd_vel, Differential Controller Node, and Articulation Controller Node is still not available. I can’t do the example part of the tutorial.
I need some help!
Even if I send the ros cmd_veltopic, the turtlebot doesn’t work, so is there a way to debug the action graph on the ros side? Or do you have any advice?
