Hi everyone,
I observe undesired behaviors, when trying to define separate ranges in the RTX LiDAR config JSON file.
The syntax in the config is like this:
"rangeCount": 6,
"ranges": [
"min": 0.5,
"max": 40.0
more ranges
I map these ranges to the scanning-directions of my solid-state LiDAR.
The minimum-(not-)working-example consists of a plane-mesh in 100m distance from the RTX LiDAR, the latter one being placed in the /World origin. The minimum-sensor has exactly one scanning-direction for each defined range.
Increasing the rangeCount and introducing more entries in the ranges-list leads on my system to different behaviors in IsaacSim:
"rangeCount":6→ No problem, the LiDAR detects surfaces. They can be visualized inrviz2."rangeCount":9→ The LiDAR does not detect surfaces anymore, at least the point clouds published by the ROS2 bridge does not contain any points."rangeCount":12→ IsaacSim instantly crashes upon clicking the “play” button to start the simulation.
The crash comes with the error:
2024-04-12 12:57:29 [44,632ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 2 in ../../../include/omni/sensors/cuda/CudaHelperMem.h:51:out of memory (cudaMallocHost(ptr, numElems * sizeof(T)))
I attached minimum-working-example files. It is one USDA file per case (1,2 and 3) and one matching config JSON file.
My system spec:
- Ubuntu 20.04 LTS
- IsaacSim 2023.1.1-rc.8+2023.1.688.573e0291.tc.linux-x86_64.release
- ROS2 Foxy
- Virtual Machine on an Nvidia OVX
Fri Apr 12 15:31:17 2024
| NVIDIA-SMI 535.154.05 Driver Version: 535.154.05 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA A40-48Q On | 00000000:02:00.0 Off | Off |
| N/A N/A P8 N/A / N/A | 0MiB / 49152MiB | 0% Default |
| | | Disabled |
| Processes: |
| ID ID Usage |
| No running processes found |
The expected and desired behavior would be that the user can specify an arbitrary number of ranges, in order to assign a min-max-range-pair to each scanning-direction of the scanning pattern.
Thanks for your help,
Markus
minimum_working_example.zip (10.3 KB)
