Hi, I’m going to flash Xavier. Terminal shows complete successfully.
Then Xavier restart. But Xavier can’t enter GUI just see the black screen after see Nvidia Logo.
Firstly, take care of the serial console first. This is the essential one to debug any kind of boot issue. Unless you are able to dump it, this issue won’t have much progress with just the description you provided.
I don’t know what is the point in your latest comment. Below is my reply.
Xavier can restart normally after typing command: sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1
→ OK, sounds expected.
So I start flashing kernel by sudo ./flash.sh -k kernel-dtb jetson-xavier mmcblk0p1
Host OS shows :
*** The [kernel-dtb] has been updated successfully. ***
Xavier also flash successfully.
Does it have something wrong about kernel?
→ Are you using the default kernel dtb from the original jetpack or it is a new dtb built by you?
And for your new questions
First, when I restart Xavier by manual. It spent up to 10 min…
We cannot tell, dump the uart serial console and the timestamp will tell us what happened.
Second, Xavier couldn’t find anything about CUDA…
I don’t know if you are new to all of this. But the default “Sample Root Filesystem” does not include CUDA. That is why sdkmanger exists. Those SDK are installed from sdkmanager.
