My question may be stupid, but if I cannot do this in a single click…
How to make the Viewport’s background white?
Even after creating a white ground, somehow it is not white. Stage lights or whatever may be causing some issues.
The easiest way to get a white background is to change the lighting to a Grey Studio.
If that doesn’t solve your issue, let us know a little more about what you’re trying to do :)
Hey @StrainFlow, thank you for the tip!
I had already tried this, but not what I am looking for. Maybe the following explanation helps.
I have an robot in Isaac Sim and I would like to have a photo of this model that could easily blend within a regular A4 paper. However, having a truly white background does not seem easy to get. I was wondering if there is some way to screenshot just the model or have a white background.
A4 paper isn’t exactly white, so if you do a white background it still won’t match your paper. If you want to include really nice shots of your robot in a document, you can set up an environment with lighting in USD composer and render some very high quality images. If you join the community on discord, I’m sure you would find them very helpful in learning how to rig shots like this.
