SD card not detecting on the jetson TX2
I have got a tx2 nx on the aver-media e715 carrier board. First i got jetpack flashed and since the tx2 nx has only 16gb of eemc and it was getting over ,i decided to use the sd card. Change Root File System to SD Card Directly i followed this to make the sd card as the root file system. This worked fine for me but i had to re-flash the tx2 nx so i formated my sd card and re-flashed it with the same jetpack. Now when i try to change the root file system to the sd card i see that the sd card is not being recognised.
What am i missing here?
You need to use the BSP provided by the carrier board vendor. Default BSP from jetpack does not support extra sdcard slot.
