SDK Manager, Cuda, Cudnn
Hello, I have some simple question. Yours SDK Manage software is designed to install OS and other plugins like CUDA, CUDNN, etc, on Jetson devices. The point of this software is that all the plugins I install should be compatible with each other and i can see them, right? How i can check if I have proper CUDA for my GPU? And shuould i need to subsequently install proper driver for my GPU or SDK Manager will do it for me? (I’m using Jetson AGX Orin (64GB Developer Kit))
Jetson GPU’s driver is integrated into the OS.
So please flash and install the packages from the same JetPack version to make sure compatibility.
