SDK Manager - Failed to get configuration file from server
I am unable to login to sdkmanager on my host computer. I receive the following message -
Appreciate any help and advice. Thanks!
Also, please find attached zip of ~/.nvsdkm directory.
nvsdkm.zip (78.7 KB)
If you’re using VM, then it’s not supported.
Please have a host PC with native Ubuntu 20.04 OS.
I’m using the same version as you did and it’s working fine.
Maybe you need to check your Internet connection.
