I’m not sure I am in the right section of the forum, so feel free to move it accordingly.
I bought a jetson agx orin and installed it in headless mode using a Mac, and everything worked fine.
Then I added an M.2 SSD and wanted to boot on this drive. I did it successfully with my previous jetson AGX, using jetsonhacks tools, so I thought I would reuse those tools to do it with my new Orin.
However, their github page mentions that it is now supported by nvidia and that we should use the sdkmanager to do it, before installing anything. Their github page remains just for history.
And here I am, with a brand new laptop and Ubuntu 22.04, as it seems that the latest version of the sdkmanager supports Ubuntu 22.
However, when I try to use the sdkmanager, this is what I get, failing at step 1 with target OS mentioning an error I don’t really get:
I had the same issue. The only way I was able to get the sdkmanager to work was to install on an Ubuntu 20.04 machine. Building and flashing the Orin from source works on Ubuntu 22.04.
Anyway, thank you very much for your feedback.
I was indeed able to build from source, but my goal for restarting the whole process is to be able to use the sdkmanager to setup the M.2 SSD as boot drive
Thank you for your help.
In the end I installed an ubuntu20.04 as dual boot on my laptop.
Anyway, I was able to use the sdkmanager to setup the jetson, and I could choose either the default eMMC or the NVMe, so I guess this part is now alright.
However, I’m still in the process of installing all this, my Orin is plugged to my laptop via the supplied USB-C cable and the install now fails, mentioning a network issue.
The thing is, my laptop can ping the jetson on said 192.168.55.1 ip address, and if instead of connection through USB I choose connection through ethernet (I also plugged an ethernet cable into the jetson as this USB option seemed to fail), I get the same error although my laptop can also ping the jetson on its ip address.
Now, when looking at the specific error:
ssh -F /dev/null -o PreferredAuthentications=password -o PubkeyAuthentication=no -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -o ConnectTimeout=5 jetson@192.168.1.193 ‘ping -c 3 nvidia.com || wget --spider -T 5 -t 1 www.nvidia.com’
I see a ping to nvidia.com. And for some reason, I fail to ping this specific domain (although I can ping www.nvidia.com or google.com)
EDIT: I realised these commands are ran on the jetson, but the results are the same. Ping to nvidia.com fails, but ping to www.nvidia.com or google.com successes on the jetson.
I must admit that I don’t know what I should fix, as I’m not sure of the issue here.
Would anyone have an idea of what the problem is, and what I should do to fix it?
Anyway, I guess at this point my primary purpose is fulfilled, which was to use the sdkmanager to setup the jetson to use the M.2 SSD.
I can now continue the install using the Debian packages, as suggested by the setup flow schema shown in pauljurczak linked thread.
Thank you all for your help.
EDIT: after deciding to complete the install process using the debian packages I clicked on ‘skip’, and then the install went on successfully…
