my Jetson SDK Manager fails after login with “failed to get configuration file from the server”. I assume I am blocked because I had a few unsuccessful login attempts: it’s complicated, working from a virtualbox VM, login is solved now.
setup:
Ubuntu 20.04 (in virtualbox VM on macbook)
SDK Manager 1.9.2.10884 x86_64
Nvidia should consider extending their support. As people mentioned already in this forum, not everyone has an Ubuntu 20.04 box waiting at home for the day the Nvidia hardware arrives.
My problem was not related to VM or VB, I think I was simply blocked. But who knows, the answer above did not help to find out what really happened.
It started working again after a few hours and the Xavier is now successfully setup using a Macbook pro VB as host (not supported, I know).
