Unlike the previous installer for Jetpack, using the SDK manager I was not able to uncheck the OpenCV installation on the target. Am I missing something obvious?
The SDK manager installs OpenCV 3.3, and I need OpenCV 3.4. There is a script at the following URL that installs OpenCV 3.4, https://github.com/AastaNV/JEP/blob/master/script/install_opencv3.4.0_TX2.sh
YES, current SDK manage will install all the package at once.
There are two alternative for you:
1. Install everything manually
CUDA
$ ./cuda-l4t.sh [deb] 10.0 10-0
CuDNN
$ sudo dpkg -i libcudnn7*
TensorRT
sudo dpkg -i libnvinfer*
sudo dpkg -i tensorrt*
2.Uninstall OpenCV afterward
sudo apt-get purge libopencv*
sudo apt-get update
This may sound redundant; the NVidia SDK Manager will install OpenCV on the HOST machine and there is no option to disable it?
The latest release of the NVidia SDK Manager (0.9.14.4964) still will install OpenCV on the HOST machine and there is no option to disable it.
