Self-collision issues in the Franka Panda examples (franka attractor)
I was adapting franka_attractor.py example and tested it in more challenging motions but I found that the simulator failed to accurately model collisions and the panda hand goes through the arm.
I suspect it happens when the hand is on top of the arm instead of the common use case where the hand is facing downwards.
I did not change the API calls, only the targets for the controller (I attached the python file for reference).
franka_attractor.py (8.1 KB)
Here is a screen capture that shows this behaviour:
Screenshot from 2023-07-10 16-19-05
I’m using isaacgym 1.0rc4 with python 3.7.12, and using the Panda URDF that comes with the isaac-sim installation.
Did anyone encounter such a problem and know how to fix it?
Thanks,
Tom
