Slow Ad-Hoc connection in nano
I am trying to connect to Nano with ad-hoc connection. I am able to connect but connction speed is slow. When I ping from another computer in ad-hoc connection, some time I get 1000ms, avarage is 270ms.
Do you have suggestions?
my wifi module is AC8265ngw (intel) in ad-hoc mode
I did not install anything else for wifi module.
I installed ubuntu fallowing the instructions in https://developer.nvidia.com/embedded/learn/get-started-jetson-nano-devkit#write
I didnt do update-upgrade after the install
Is this only happened in ad-hoc mode or even AP mode and station mode?
the pings in the local wifi network of my home:
As seen here it is only slow in ad-hoc mode
by the way I did my ad-hoc settings by adding
autowlan0
iface wlan0 inet static
adress <my-ip>
netmask
wireless-channel 1
wireless-essid <myssid>
wireless-mod ad-hoc
to etc/network/interfaces
for reference pings in ad-hoc mode :
(sytem didnt allow me to post two pics in one post and post this immediately, because I am new)
Could you connect this 8265 device to your host and try to see if this ad-hoc slow issue can be seen on host too?
by host do you mean My computer or something else ?
Yes, any other devices.
I did not encounter anything like this when I plug it into my computer
When I use raspberry pi, I see 7-8 ms delay in ad hoc mode again.(internal wifi device)
When I compared the tx powers, I saw that raspberrypin was 31dbm 8265 was 20 db.Will this affect the delay in the ping?
When I enter the following command to the console, In my network, ping delay is decreasing but adhoc network delay did not change.
iw dev wlan0 set power_save off
hello
Do you solve this problem?
I met the same problem of you that slow adhoc in jetson nano
sorry i dont remember if i actaully solved it. But i think it was something related to nvidia limiting the power and not letting user messing with those setting.
