SoftBody Puncturing
Hello everyone,
I am a current master’s student working on a soft tissue simulation where I want a suture needle to pierce through the tissue and get the tissue to cinch together when I tie a knot. I was wondering what would be the best way to implement this? Is it possible to edit the collision tetrahedra as the needle moves through the softbody? Would I just have to set kinematic targets for the deformable body vertices? Any help would be greatly appreciated.
Hi @nnim,
Soft body puncturing/cutting (topology changes) is not currently supported by PhysX’s deformable body simulation — the tetrahedral mesh topology is fixed at creation time. PhysX deformables support vertex deformation via kinematic targets
and external forces, but not mesh splitting or piercing.
For surgical needle/suture simulation, this would require either:
  • A custom implementation that modifies the tet mesh outside PhysX and re-creates the deformable body
  • Using a different simulation backend (e.g., SOFA framework) for the tissue mechanics, potentially coupled with Isaac Sim for rendering/environment
This is a PhysX feature limitation rather than an Isaac Sim issue. For physics feature requests, the Physics Simulation forum category may be more appropriate.
Closing due to age. For Isaac Sim questions, we now use GitHub Discussions.
