You need to use flash_l4t_external.xml instead of flash_l4t_t194_nvme.xml.
Check:
Check:
| Facing issue while installing nvidia jetpack sdk's | 1 | 102 | July 18, 2024 | |
| Installing jetpack on jetson xavier nx via SDK Manager always fails | 10 | 868 | February 9, 2024 | |
| How to fix flashed Jetson NX using 16GB partition | 3 | 715 | December 25, 2023 | |
| Can't flash Xavier NX due to not enough space on the APP partition | 2 | 622 | October 23, 2023 | |
| Flash Jetpack 5.1.2 into Xavier Nx | 1 | 161 | November 29, 2024 | |
| Jetson Xavier NX flash to nvme / flash bootloader only | 6 | 757 | December 14, 2023 | |
| Jetson Xavier AGX Flash to NVMe SSD resize | 1 | 567 | February 5, 2024 | |
| Flashing nvme problems | 2 | 444 | March 1, 2024 | |
| It is installed with the sdkmanger in ssd, and the partition of ssd is divided into self-care, and there is an error in the lack of storage space | 2 | 1142 | August 22, 2023 | |
| Jetson Nano Sdk Manager 14 GB of space for the Linux file system | 2 | 748 | September 15, 2023 |
