We have custom board with an ADIS165000 attached to SPI2 or spi@3230000
CS:0
Eventually, I would like to take advantage of a burst feature of this chip wherein I can copy all the IMU data from the chip with a single long read transaction but I’m having trouble capturing more than a single transaction at a time. To reduce this problem down in this post, I’m focusing on two consecutive transactions.
This topic is similar to Jetpack 5.0.2 crashes when it tries to transfer SPI message with SPI_IOC_MESSAGE(N), N > 1
For reference:
$ cat /etc/nv_tegra_release
# R35 (release), REVISION: 1.0, GCID: 31346300, BOARD: t186ref, EABI: aarch64, DATE: Thu Aug 25 18:41:45 UTC 2022
Here is my SPI DTSI snippet:
#include <dt-bindings/gpio/tegra-gpio.h>
spi@3230000{ /* SPI3 in 40 pin conn */
status = "okay";
spi@0 { /* chip select 0 */
compatible = "tegra-spidev";
reg = <0x0>;
//spi-max-frequency = <50000000>;
spi-max-frequency = <25000000>; /* 25MHz */
controller-data {
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x10>;
nvidia,tx-clk-tap-delay = <0x0>;
spi@1 { /* chips select 1 */
reg = <0x1>;
controller-data {
I’ve verified that I can read and write to the device a single 16-bit word at a time:
Here is a snippet of the ‘read_register’ function where the read schema is the following
- Transfer one 16-bit transaction where the TX buffer has the requested address in the high byte and 0x00 in the low byte, ignore the read.
- Transfer one 16-bit transaction where the TX buffer doesn’t matter but the read buffer will have the 16-bit register value
VERSION 1
// Send one 16-bit value to the IMU through the 'tx_buf'
// Read one 16-bit value from the IMU through the 'rx_buf'
// Between the two transactions de-assert 'cs'
// Configure the SPI Transfer
uint16_t spi_addr = (addr << 8) & 0xFF00;
uint16_t tx_buf_msg0[8] = {spi_addr};
uint16_t rx_buf_msg0[8] = {0x0000};
uint16_t tx_buf_msg1[8] = {spi_addr};
uint16_t rx_buf_msg1[8] = {0x0000};
tx_buf_msg0[0] = spi_addr;
tx_buf_msg0[1] = spi_addr;
printf("TX Buffer: 0x%04X\n", tx_buf_msg0[0]);
m_spi_transfer[0].speed_hz = SPI_FREQ; // 1MHz
m_spi_transfer[0].cs_change = 1; // Change at the end of the transaction
m_spi_transfer[0].bits_per_word = 16; // 16-bit word
m_spi_transfer[0].len = 2; // 1 16-bit word
m_spi_transfer[0].tx_buf = (unsigned long)tx_buf_msg0; // Attach TX Buffer
m_spi_transfer[0].rx_buf = (unsigned long)rx_buf_msg0; // Attach RX Buffer
rv = ioctl(spidev_fd, SPI_IOC_MESSAGE(1),
&m_spi_transfer[0]); // Send 1 messeges
if (rv < 0)
printf("Error 0 from IOCTL When Reading Register: %02X: RV: %d\n", addr,
rv);
m_spi_transfer[1].speed_hz = SPI_FREQ; // 1MHz
m_spi_transfer[1].cs_change = 1; // Change at the end of the transaction
m_spi_transfer[1].bits_per_word = 16; // 16-bit word
m_spi_transfer[1].len = 2; // 1 16-bit word
m_spi_transfer[1].tx_buf = (unsigned long)tx_buf_msg1; // Attach TX Buffer
m_spi_transfer[1].rx_buf = (unsigned long)rx_buf_msg1; // Attach RX Buffer
&m_spi_transfer[1]); // Send 1 messeges
if (rv < 0)
printf("Error 1 from IOCTL When Reading Register: %02X: RV: %d\n", addr,
rv);
printf("Recevied Data 0: 0x%04X\n", rx_buf_msg0[0]);
printf("Recevied Data 1: 0x%04X\n", rx_buf_msg1[0]);
value = rx_buf_msg1[0];
return rv;
This works with the expected result
TX Buffer: 0x7200
Recevied Data 0: 0x0000
Recevied Data 1: 0x4074
Now when I change it so that there is two words within a transaction:
VERSION 2
// 2 x 16-bit transactions
uint16_t tx_buf_msg[8] = {spi_addr};
uint16_t rx_buf_msg[8] = {0x0000};
memset(tx_buf_msg, 0, sizeof(tx_buf_msg));
tx_buf_msg[0] = spi_addr;
tx_buf_msg[1] = spi_addr;
printf("First 2 Words of TX Buffer: 0x%04X 0x%04X\n", tx_buf_msg[0],
tx_buf_msg[1]);
m_spi_transfer[0].cs_change = 1; // De-assert CS between the two words
m_spi_transfer[0].len = 4; // 1 16-bit word
m_spi_transfer[0].tx_buf = (unsigned long)tx_buf_msg; // Attach TX Buffer
m_spi_transfer[0].rx_buf = (unsigned long)rx_buf_msg; // Attach RX Buffer
rv = ioctl(spidev_fd, SPI_IOC_MESSAGE(2), &m_spi_transfer[0]);
if (rv < 0)
rv);
printf("Recevied Data: 0x%04X, 0x%04X\n", rx_buf_msg[0], rx_buf_msg[1]);
value = rx_buf_msg[1];
return rv;
The result is not correct:
First 2 Words of TX Buffer: 0x7200 0x7200
Recevied Data: 0x0000, 0x0000
Stuff I’ve tried
I’ve enabled tracing on the spi subsystem using the following commands:
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/spi/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace_pipe
For VERSION 1
adis-imu-contro-5443 [000] d..1 3795.675809: spi_message_submit: spi2.0 00000000e6ed7e8a
adis-imu-contro-5443 [001] .... 3795.680923: spi_controller_busy: spi2
adis-imu-contro-5443 [001] .... 3795.680972: spi_message_start: spi2.0 00000000e6ed7e8a
spi2-361 [001] .... 3795.681341: spi_controller_idle: spi2
adis-imu-contro-5443 [001] .... 3795.681426: spi_message_done: spi2.0 00000000e6ed7e8a len=2/2
adis-imu-contro-5443 [001] d..1 3795.681521: spi_message_submit: spi2.0 00000000e6ed7e8a
adis-imu-contro-5443 [001] .... 3795.682144: spi_controller_busy: spi2
adis-imu-contro-5443 [001] .... 3795.682149: spi_message_start: spi2.0 00000000e6ed7e8a
spi2-361 [001] .... 3795.682346: spi_controller_idle: spi2
adis-imu-contro-5443 [001] .... 3795.682376: spi_message_done: spi2.0 00000000e6ed7e8a len=2/2
For VERSION 2
adis-imu-contro-5299 [001] d..1 3492.761065: spi_message_submit: spi2.0 00000000652afe5f
adis-imu-contro-5299 [001] .... 3492.761444: spi_controller_busy: spi2
adis-imu-contro-5299 [001] .... 3492.762044: spi_message_start: spi2.0 00000000652afe5f
spi2-361 [001] .... 3492.762345: spi_controller_idle: spi2
adis-imu-contro-5299 [001] .... 3492.762524: spi_message_done: spi2.0 00000000652afe5f len=4/4
I do notice that when I switch between VERSION 2 to VERSION 1 I need to run that application a few times before the application usually behaves, it seems there is some data in a buffer that hasn’t been cleared out.
Applying Patch to spi-tegra114.c
In the other post I see that there was a request to apply a patch to the driver. I did this and was able to get some data but when I added more print messages to identify where the register dumps were occurring, The kernel became unstable and panicked.
Here is the patch I applied to spi-tegra114.c
diff --git a/drivers/spi/spi-tegra114.c b/drivers/spi/spi-tegra114.c
index d50705047a02..150cdd62f0ae 100644
--- a/drivers/spi/spi-tegra114.c
+++ b/drivers/spi/spi-tegra114.c
@@ -267,6 +267,7 @@ struct tegra_spi_data {
static int tegra_spi_runtime_suspend(struct device *dev);
static int tegra_spi_runtime_resume(struct device *dev);
static int tegra_spi_status_poll(struct tegra_spi_data *tspi);
+static void tegra_spi_dump_regs(struct tegra_spi_data *tspi);
static inline u32 tegra_spi_readl(struct tegra_spi_data *tspi,
unsigned long reg)
@@ -725,6 +726,8 @@ static int tegra_spi_start_dma_based_transfer(
tspi->dma_control_reg = val;
val |= SPI_DMA_EN;
+ dev_err(tspi->dev, "%s: %d\n", __func__, __LINE__);
+ tegra_spi_dump_regs(tspi);
tegra_spi_writel(tspi, val, SPI_DMA_CTL);
return ret;
@@ -763,6 +766,8 @@ static int tegra_spi_start_cpu_based_transfer(
val = tspi->command1_reg;
val |= SPI_PIO;
tegra_spi_writel(tspi, val, SPI_COMMAND1);
return 0;
@@ -1354,14 +1359,14 @@ static int tegra_spi_setup(struct spi_device *spi)
- dev_dbg(tspi->dev, "============ SPI REGISTER DUMP ============\n");
- dev_dbg(tspi->dev, "Command1: 0x%08x | Command2: 0x%08x\n",
+ dev_err(tspi->dev, "============ SPI REGISTER DUMP ============\n");
+ dev_err(tspi->dev, "Command1: 0x%08x | Command2: 0x%08x\n",
tegra_spi_readl(tspi, SPI_COMMAND1),
tegra_spi_readl(tspi, SPI_COMMAND2));
- dev_dbg(tspi->dev, "DMA_CTL: 0x%08x | DMA_BLK: 0x%08x\n",
+ dev_err(tspi->dev, "DMA_CTL: 0x%08x | DMA_BLK: 0x%08x\n",
tegra_spi_readl(tspi, SPI_DMA_CTL),
tegra_spi_readl(tspi, SPI_DMA_BLK));
- dev_dbg(tspi->dev, "TRANS_STAT: 0x%08x | FIFO_STATUS: 0x%08x\n",
+ dev_err(tspi->dev, "TRANS_STAT: 0x%08x | FIFO_STATUS: 0x%08x\n",
tegra_spi_readl(tspi, SPI_TRANS_STATUS),
tegra_spi_readl(tspi, SPI_FIFO_STATUS));
@@ -1467,6 +1472,7 @@ static int tegra_spi_transfer_one_message(struct spi_controller *ctrl,
(tspi->cur_direction & DATA_DIR_RX))
dmaengine_terminate_all(tspi->rx_dma_chan);
ret = -EIO;
/* Abort transfer by resetting pio/dma bit */
if (!tspi->is_curr_dma_xfer) {
@@ -1490,6 +1496,7 @@ static int tegra_spi_transfer_one_message(struct spi_controller *ctrl,
if (tspi->tx_status || tspi->rx_status) {
dev_err(tspi->dev, "Error in Transfer\n");
ret = -EIO;
goto complete_xfer;
@@ -1563,6 +1570,7 @@ static irqreturn_t handle_cpu_based_xfer(struct tegra_spi_data *tspi)
tspi->status_reg);
dev_err(tspi->dev, "CpuXfer 0x%08x:0x%08x\n",
tspi->command1_reg, tspi->dma_control_reg);
complete(&tspi->xfer_completion);
spin_unlock_irqrestore(&tspi->lock, flags);
@@ -1584,6 +1592,8 @@ static irqreturn_t handle_cpu_based_xfer(struct tegra_spi_data *tspi)
if (tspi->cur_pos == t->len) {
goto exit;
@@ -1639,6 +1649,7 @@ static irqreturn_t handle_dma_based_xfer(struct tegra_spi_data *tspi)
tspi->status_reg);
dev_err(tspi->dev, "DmaXfer 0x%08x:0x%08x\n",
@@ -1660,6 +1671,8 @@ static irqreturn_t handle_dma_based_xfer(struct tegra_spi_data *tspi)
goto exit;
Here is a capture of the kernel panic
[ 249.643076] spi-tegra114 3230000.spi: tegra_spi_start_cpu_based_transfer: 769
[ 249.643274] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 249.643451] spi-tegra114 3230000.spi: Command1: 0x70e0980f | Command2: 0x00000015
[ 249.643741] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 249.643935] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0000 | FIFO_STATUS: 0x00400005
[ 249.644228] spi-tegra114 3230000.spi: handle_cpu_based_xfer: 1595
[ 249.644352] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 249.644508] spi-tegra114 3230000.spi: Command1: 0x40c08000 | Command2: 0x00000015
[ 249.644715] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 249.644899] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0001 | FIFO_STATUS: 0x00400005
[ 249.652095] spi-tegra114 3230000.spi: tegra_spi_start_cpu_based_transfer: 769
[ 249.652379] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 249.652784] spi-tegra114 3230000.spi: Command1: 0x70c0980f | Command2: 0x00000015
[ 249.653164] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 249.659675] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0001 | FIFO_STATUS: 0x00400005
[ 249.667692] spi-tegra114 3230000.spi: handle_cpu_based_xfer: 1595
[ 249.673452] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 249.681239] spi-tegra114 3230000.spi: Command1: 0x70c0980f | Command2: 0x00000015
[ 249.689288] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 249.697337] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0001 | FIFO_STATUS: 0x00400005
[ 249.715965] spi-tegra114 3230000.spi: tegra_spi_start_cpu_based_transfer: 769
[ 249.716193] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 249.719983] spi-tegra114 3230000.spi: Command1: 0x70c0980f | Command2: 0x00000015
[ 249.728308] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 249.736076] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0001 | FIFO_STATUS: 0x00400005
[ 249.744414] spi-tegra114 3230000.spi: handle_cpu_based_xfer: 1595
[ 249.750119] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 249.757630] spi-tegra114 3230000.spi: Command1: 0x70c0980f | Command2: 0x00000015
[ 249.765680] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 249.773743] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0001 | FIFO_STATUS: 0x00400005
[ 249.782944] spi-tegra114 3230000.spi: tegra_spi_start_cpu_based_transfer: 769
[ 249.789270] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 249.796802] spi-tegra114 3230000.spi: Command1: 0x70c0980f | Command2: 0x00000015
[ 249.804633] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 249.813546] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0001 | FIFO_STATUS: 0x00400005
[ 249.820978] spi-tegra114 3230000.spi: handle_cpu_based_xfer: 1595
[ 249.826754] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 249.834283] spi-tegra114 3230000.spi: Command1: 0x40c08000 | Command2: 0x00000015
[ 249.842332] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 249.850639] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0001 | FIFO_STATUS: 0x00400005
[ 249.859684] spi-tegra114 3230000.spi: tegra_spi_start_cpu_based_transfer: 769
[ 249.865738] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 249.873454] spi-tegra114 3230000.spi: Command1: 0x70c0980f | Command2: 0x00000015
[ 249.881257] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 249.889306] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0001 | FIFO_STATUS: 0x00400005
[ 249.897594] spi-tegra114 3230000.spi: handle_cpu_based_xfer: 1595
[ 249.898557] spi-tegra114 3230000.spi: tegra_spi_start_cpu_based_transfer: 769
[ 249.903400] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 249.903409] spi-tegra114 3230000.spi: Command1: 0x70c0980f | Command2: 0x00000015
[ 249.903415] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 249.903421] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0001 | FIFO_STATUS: 0x00400005
[ 249.942321] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 249.951044] spi-tegra114 3230000.spi: Command1: 0x70c0980f | Command2: 0x00000015
[ 249.957943] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 249.966051] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0001 | FIFO_STATUS: 0x00400005
[ 249.974952] spi-tegra114 3230000.spi: handle_cpu_based_xfer: 1595
[ 249.979966] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 249.987496] spi-tegra114 3230000.spi: Command1: 0x40c08000 | Command2: 0x00000015
[ 249.991288] spi-tegra114 3230000.spi: tegra_spi_start_cpu_based_transfer: 769
[ 249.995801] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 249.995809] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0001 | FIFO_STATUS: 0x00400005
[ 250.018940] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 250.026502] spi-tegra114 3230000.spi: Command1: 0x70c0980f | Command2: 0x00000015
[ 250.034797] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 250.042590] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0001 | FIFO_STATUS: 0x00400005
[ 250.050928] spi-tegra114 3230000.spi: handle_cpu_based_xfer: 1595
[ 250.050973] spi-tegra114 3230000.spi: tegra_spi_start_cpu_based_transfer: 769
[ 250.056958] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 250.056967] spi-tegra114 3230000.spi: Command1: 0x70c0980f | Command2: 0x00000015
[ 250.056974] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 250.056980] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0001 | FIFO_STATUS: 0x00400005
[ 250.095593] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 250.103427] spi-tegra114 3230000.spi: Command1: 0x70c0980f | Command2: 0x00000015
[ 250.111462] spi-tegra114 3230000.spi: DMA_CTL: 0x00000000 | DMA_BLK: 0x00000000
[ 250.119268] spi-tegra114 3230000.spi: TRANS_STAT: 0x00ff0001 | FIFO_STATUS: 0x00400005
[ 250.127573] spi-tegra114 3230000.spi: handle_cpu_based_xfer: 1595
[ 250.133525] spi-tegra114 3230000.spi: ============ SPI REGISTER DUMP ============
[ 250.305282] spi-tegra114 3230000.spi: Command1: 0xdead2003 | Command2: 0xdead2003
[ 250.469948] spi-tegra114 3230000.spi: DMA_CTL: 0xdead2003 | DMA_BLK: 0xdead2003
[ 250.634638] spi-tegra114 3230000.spi: TRANS_STAT: 0xdead2003 | FIFO_STATUS: 0xdead2003
[ 250.635012] CPU:0, Error:cbb-noc@0x2300000,irq=15
[ 250.635105] **************************************
[ 250.635200] CPU:0, Error:cbb-noc
[ 250.635266] Error Logger : 0
[ 250.635348] ErrLog0 : 0x80030000
[ 250.635421] Transaction Type : RD - Read, Incrementing
[ 250.635525] Error Code : SLV
[ 250.635591] Error Source : Target
[ 250.635661] Error Description : Target error detected by CBB slave
[ 250.635803] AXI2APB_4 bridge error: SFIFONE - Status FIFO Not Empty interrupt
[ 250.635948] AXI2APB_4 bridge error: TIM - Timer(Timeout) interrupt
[ 250.636073] AXI2APB_5 bridge error: RDFIFOF - Read Response FIFO Full interrupt
[ 250.636220] Packet header Lock : 0
[ 250.636291] Packet header Len1 : 3
[ 250.636380] NOC protocol version : version >= 2.7
[ 250.636476] ErrLog1 : 0x320028
[ 250.636687] ErrLog2 : 0x0
[ 250.636878] RouteId : 0x320028
[ 250.637129] InitFlow : ccroc_p2ps/I/ccroc_p2ps
[ 250.638047] Targflow : axis_satellite_grout/T/axis_satellite_grout
[ 250.644610] TargSubRange : 0
[ 250.647847] SeqId : 0
[ 250.650477] ErrLog3 : 0x3230000
[ 250.654146] ErrLog4 : 0x0
[ 250.656947] Address accessed : 0x3230000
[ 250.661163] ErrLog5 : 0xa09f851
[ 250.664384] Non-Modify : 0x1
[ 250.667796] AXI ID : 0x14
[ 250.670859] Master ID : CCPLEX
[ 250.674271] Security Group(GRPSEC): 0x7e
[ 250.678214] Cache : 0x1 -- Bufferable
[ 250.682686] Protection : 0x2 -- Unprivileged, Non-Secure, Data Access
[ 250.689496] FALCONSEC : 0x0
[ 250.692389] Virtual Queuing Channel(VQC): 0x0
[ 250.697285] **************************************
[ 250.702332] kernel BUG at drivers/soc/tegra/cbb/tegra194-cbb.c:1896!
[ 250.708662] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 250.714000] Modules linked in: fuse aes_ce_ccm rtl8xxxu rtl8192cu rtl_usb rtl8192c_common rtlwifi mac80211 snd_soc_tegra186_asrc snd_soc_tegra210_ope cfg80211 snd_soc_tegra186_dspk snd_soc_tegra186_arad snd_soc_tegra210_mvc snd_soc_tegra210_afc snd_soc_tegra210_iqc snd_soc_tegra210_dmic xt_conntrack ofpart cmdlinepart snd_soc_tegra210_admaif qspi_mtd xt_MASQUERADE snd_soc_tegra210_amx snd_soc_tegra210_adx nf_conntrack_netlink nfnetlink snd_soc_tegra210_mixer snd_soc_tegra_pcm snd_soc_tegra210_i2s mtd xt_addrtype snd_soc_tegra210_sfc iptable_filter iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c br_netfilter lzo_rle lzo_compress zram overlay aes_ce_blk crypto_simd cryptd aes_ce_cipher ghash_ce sha2_ce sha256_arm64 sha1_ce realtek loop snd_soc_spdif_tx snd_soc_tegra210_adsp leds_gpio snd_hda_codec_hdmi snd_soc_tegra_machine_driver snd_soc_tegra_utils snd_hda_tegra snd_soc_simple_card_utils snd_hda_codec spidev ina3221 pwm_fan max77620_thermal nvadsp tegra_bpmp_thermal
[ 250.714277] tegra210_adma snd_soc_tegra210_ahub snd_hda_core userspace_alert nvgpu imx265 spi_tegra210_qspi imx265_fpga spi_tegra114 binfmt_misc nvmap ramoops reed_solomon ip_tables x_tables
[ 250.818656] CPU: 0 PID: 346 Comm: irq/36-3230000. Tainted: G OE 5.10.104-tegra #3
[ 250.827833] Hardware name: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVIDIA Jetson Xavier NX Developer Kit, BIOS 1.0-d7fb19b 08/10/2022
[ 250.840181] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=--)
[ 250.846480] pc : tegra194_cbb_err_isr+0x190/0x1b0
[ 250.851198] lr : tegra194_cbb_err_isr+0x114/0x1b0
[ 250.855664] sp : ffff800010003b30
[ 250.859334] x29: ffff800010003b30 x28: 0000000000000001
[ 250.864847] x27: 0000000000000005 x26: ffffb4b8ed6e5d48
[ 250.869927] x25: ffffb4b8ee135e18 x24: 0000000000000001
[ 250.875439] x23: ffffb4b8eda07000 x22: ffffb4b8edf0eaa0
[ 250.881208] x21: 000000000000000f x20: ffff23b7c0eecc80
[ 250.886290] x19: ffffb4b8edf0eaa0 x18: 0000000000000010
[ 250.891802] x17: 0000000000000000 x16: ffffb4b8ed177ea0
[ 250.897397] x15: ffff23b7f1122270 x14: ffffffffffffffff
[ 250.902910] x13: ffff800090003727 x12: ffff80001000372f
[ 250.908422] x11: 0000000000000038 x10: 0101010101010101
[ 250.913937] x9 : ffff800010003a40 x8 : 2a2a2a2a2a2a2a2a
[ 250.919446] x7 : 2a2a2a2a2a2a2a09 x6 : c0000000ffffefff
[ 250.924959] x5 : ffff23bb3fd9b958 x4 : ffffb4b8edd97968
[ 250.930384] x3 : 0000000000000001 x2 : ffffb4b8ec0ff1d0
[ 250.935465] x1 : ffff23b7f1121d00 x0 : 0000000100010101
[ 250.940801] Call trace:
[ 250.943256] tegra194_cbb_err_isr+0x190/0x1b0
[ 250.947562] __handle_irq_event_percpu+0x68/0x2a0
[ 250.952350] handle_irq_event_percpu+0x40/0xa0
[ 250.956812] handle_irq_event+0x50/0xf0
[ 250.960576] handle_fasteoi_irq+0xc0/0x170
[ 250.964356] generic_handle_irq+0x40/0x60
[ 250.968625] __handle_domain_irq+0x70/0xd0
[ 250.972838] efi_header_end+0xb0/0xf0
[ 250.976323] el1_irq+0xd0/0x180
[ 250.979056] __do_softirq+0xb4/0x3e8
[ 250.982977] irq_exit+0xc0/0xe0
[ 250.985950] __handle_domain_irq+0x74/0xd0
[ 250.989973] efi_header_end+0xb0/0xf0
[ 250.993648] el1_irq+0xd0/0x180
[ 250.996628] _raw_spin_unlock_irqrestore+0x38/0x70
[ 251.001183] handle_cpu_based_xfer+0x88/0x2b0 [spi_tegra114]
[ 251.007038] tegra_spi_isr_thread+0x40/0x50 [spi_tegra114]
[ 251.012117] irq_thread_fn+0x34/0xa0
[ 251.015704] irq_thread+0x158/0x250
[ 251.019379] kthread+0x148/0x170
[ 251.023049] ret_from_fork+0x10/0x24
[ 251.026386] Code: a9425bf5 a9446bf9 a8c77bfd d65f03c0 (d4210000)
[ 251.032855] ---[ end trace 379708d6d2a7ce84 ]---
[ 251.037139] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
[ 251.044667] SMP: stopping secondary CPUs
[ 251.048783] Kernel Offset: 0x34b8dbf40000 from 0xffff800010000000
[ 251.055071] PHYS_OFFSET: 0xffffdc4940000000
[ 251.058928] CPU features: 0x8240002,03802a30
[ 251.063388] Memory Limit: none
[ 251.066547] ---[ end Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt ]---
In my naive opinion it does seem like a critical function may be called twice:
Thanks for any help,
Dave
