Hi all,
After updating my Jetson AGX Xavier to Jetson Linux 35.6.0 following the Over-The-Air Update guide, I ran into an issue.
Post sudo reboot, I confirmed the device was reachable by ping, but SSH attempts using the old credentials (ssh <username>@<ip>) returned:
ssh: connect to host <ip> port 22: Connection refused
Is there a way to restore SSH access remotely without physical intervention and without using USB? I specifically chose OTA over SDK Manager because of this. I only have VPN network access and no physical access.
Any help would be greatly appreciated!
hello peter.hofinger,
it may due to remote host identification has changed,
please try below… $ ssh-keygen -f "/home/<account>/.ssh/known_hosts" -R "IP-Address"
Hello JerryChang,
sorry for my late response, I was on sick leave last week. I tried your ssh-keygen command. It successfully updated the known_hosts on my machine but I still get the ssh: connect to host <ip> port 22: Connection refused error.
I debugged it using nmap and rpcinfo:
$ nmap <ip>
Starting Nmap 7.80 ( https://nmap.org ) at 2024-11-11 09:48 CET
Nmap scan report for <ip>
Host is up (0.0014s latency).
Not shown: 999 closed ports
PORT STATE SERVICE
111/tcp open rpcbind
Nmap done: 1 IP address (1 host up) scanned in 0.07 seconds
$ rpcinfo -p <ip>
program vers proto port service
100000 4 tcp 111 portmapper
100000 3 tcp 111 portmapper
100000 2 tcp 111 portmapper
100000 4 udp 111 portmapper
100000 3 udp 111 portmapper
100000 2 udp 111 portmapper
Apparently only port 111 is open with portmapper service. I organized physical access to this particular Jetson AGX Xavier unit to configure it in person tomorrow. Can I provide any logs that help you diagnose my issue?
Thank you for your help!
I discovered why SSH wasn’t functioning: after the OTA update, the Jetson booted into the initial setup screen. Once I completed the configuration, SSH started working. How can I configure the OTA process to retain the existing setup and bypass the initial setup screen? I have multiple Jetson AGX Xavier units deployed across various countries, so traveling just to input credentials isn’t a cost-effective solution.
you may try Skipping oem-config to create a default user.
Incidentally, once you use the method @JerryChang shows, there will be a home directory with that user in the host PC’s “Linux_for_Tegra/rootfs/”. Any changes you make there will exist after a flash. For example, if you were to edit the “~/.bashrc”, then that would exist after flash. If you were to copy any old ssh keys (either host or user) to that “rootfs/” content, then this too would be instantly present after a flash. If you back up the running Jetson to the “rootfs/”, e.g., via rsync, then this is what you would get after flash.
The part which won’t stay is that during a flash the kernel and/or boot content, including the initrd, can change. Content outside of that can easily be preserved to the flash content of the host PC.
Thank you so much! It works flawlessly, the user exists and I can successfully connect via SSH.
Also thank you @linuxdev for your tip. In my case the only necessary config is the user creation.
