I am stuck in this error while I am installing JetPack for TX1 on Linux Host.
JetPack installer in Linux host try to login to the TX1 device using ssh.
And the error message is :
Return Code: 1
Error: Cannot connect to device with given information. Please check your input and try again.
Detailed info:
sshpass: invalid option – ‘o’
Usage: sshpass [-f|-d|-p|-e] [-hV] command parameters
-f filename Take password to use from file
-d number Use number as file descriptor for getting password
-p password Provide password as argument (security unwise)
-e Password is passed as env-var “SSHPASS”
With no parameters - password will be taken from stdin
-h Show help (this screen)
-V Print version information
At most one of -f, -d, -p or -e should be used
On Linux host terminal, I can login to the device using ssh.
I guess JetPack installer uses different ssh options.
If anyone know the ssh options that Jetpack uses, please let me know.
