Hello - I am working generating Synthetic data from an animation I have recorded using the Stage Recorder Extension. I have successfully saved the animation as a usd and can play it by pressing the play button. However after the animation is finished the simulation doesn’t automatically stop. I am trying to use this animation to generate a synthetic dataset by following the scene_based_sdg.py example however I cannot find out how to do this with a pre-generated animation. In particular I don’t know how to set the start and stop conditions in the case of an animation. How would I go about modifying the snippet below for my approach?
Related topics
| Generating Synthetic Data with preset Animation | 2 | 642 | August 8, 2023 | |
| Synthetic data recorder freeze | 0 | 168 | May 27, 2024 | |
| Cannot run synthetic data recorder twice/Physics animation not started | 6 | 509 | March 22, 2023 | |
| Convert animation to usd file for biped_setup animation graph | 2 | 100 | March 28, 2025 | |
| Adding animations to objects | 2 | 88 | August 16, 2024 | |
| Synthetic data generation | 2 | 201 | September 6, 2024 | |
| How can i play and stop stage with extension of kit | 3 | 1199 | June 22, 2022 | |
| Starting synthetic data recorder through script | 6 | 1033 | August 8, 2023 | |
| Data Collection | 4 | 190 | August 11, 2025 | |
| Recording Human Simulation Animation (omni.anim.people) | 3 | 714 | March 31, 2023 |
