Synthetic data recorder freeze
I’m trying to generate data using the synthetic data recorder.
However an issue occurs that the data recorder freezes after generating a few frames.
If im only generating RGB its usually ok and runs until the specified number of frames ends.
If I add bounding boxes, semantic segmentation and skeleton (or one or two of them) it freezes after generating a few frames and does not resume.
This is the end of the log, as seen theres no crash and it freezes after the last frame
2024-05-27 19:43:49 [979,069ms] [Info] [omni.replicator.core.scripts.backends.disk] Writing /home/selim/Documents/omniverse/data_gen/test-genene/_out_sdrec/occlusion_0142.npy
2024-05-27 19:43:49 [979,089ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.anim.navigation.core.plugin; not changing unload order
2024-05-27 19:43:49 [979,090ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.anim.navigation.core.plugin; not changing unload order
2024-05-27 19:43:49 [979,094ms] [Info] [omni.replicator.core.scripts.backends.disk] Writing /home/selim/Documents/omniverse/data_gen/test-genene/_out_sdrec/rgb_0142.png
2024-05-27 19:43:49 [979,136ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.timeline.plugin; not changing unload order
2024-05-27 19:43:49 [979,196ms] [Info] [omni.replicator.core.scripts.backends.disk] Writing /home/selim/Documents/omniverse/data_gen/test-genene/_out_sdrec/occlusion_0143.npy
2024-05-27 19:43:49 [979,204ms] [Info] [omni.replicator.core.scripts.backends.disk] Writing /home/selim/Documents/omniverse/data_gen/test-genene/_out_sdrec/skeleton_0143.json
2024-05-27 19:43:49 [979,227ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.anim.navigation.core.plugin; not changing unload order
2024-05-27 19:43:49 [979,228ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.anim.navigation.core.plugin; not changing unload order
2024-05-27 19:43:49 [979,229ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.anim.navigation.core.plugin; not changing unload order
2024-05-27 19:43:49 [979,239ms] [Info] [omni.replicator.core.scripts.backends.disk] Writing /home/selim/Documents/omniverse/data_gen/test-genene/_out_sdrec/rgb_0143.png
2024-05-27 19:43:49 [979,270ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.timeline.plugin; not changing unload order
2024-05-27 19:43:49 [979,316ms] [Info] [omni.replicator.core.scripts.backends.disk] Writing /home/selim/Documents/omniverse/data_gen/test-genene/_out_sdrec/occlusion_0144.npy
2024-05-27 19:43:49 [979,324ms] [Info] [omni.replicator.core.scripts.backends.disk] Writing /home/selim/Documents/omniverse/data_gen/test-genene/_out_sdrec/skeleton_0144.json
2024-05-27 19:43:49 [979,346ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.anim.navigation.core.plugin; not changing unload order
2024-05-27 19:43:49 [979,347ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.anim.navigation.core.plugin; not changing unload order
2024-05-27 19:43:49 [979,348ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.anim.navigation.core.plugin; not changing unload order
2024-05-27 19:43:49 [979,349ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.anim.navigation.core.plugin; not changing unload order
2024-05-27 19:43:49 [979,353ms] [Info] [omni.replicator.core.scripts.backends.disk] Writing /home/selim/Documents/omniverse/data_gen/test-genene/_out_sdrec/rgb_0144.png
2024-05-27 19:43:50 [979,391ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.timeline.plugin; not changing unload order
2024-05-27 19:43:50 [979,448ms] [Info] [omni.replicator.core.scripts.backends.disk] Writing /home/selim/Documents/omniverse/data_gen/test-genene/_out_sdrec/skeleton_0145.json
2024-05-27 19:43:50 [979,448ms] [Info] [omni.replicator.core.scripts.backends.disk] Writing /home/selim/Documents/omniverse/data_gen/test-genene/_out_sdrec/occlusion_0145.npy
2024-05-27 19:43:50 [979,462ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.anim.navigation.core.plugin; not changing unload order
2024-05-27 19:43:50 [979,463ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.anim.navigation.core.plugin; not changing unload order
2024-05-27 19:43:50 [979,464ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.anim.navigation.core.plugin; not changing unload order
2024-05-27 19:43:50 [979,487ms] [Info] [omni.replicator.core.scripts.backends.disk] Writing /home/selim/Documents/omniverse/data_gen/test-genene/_out_sdrec/rgb_0145.png
2024-05-27 19:43:50 [979,505ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.timeline.plugin; not changing unload order
2024-05-27 19:43:50 [979,562ms] [Info] [omni.replicator.core.scripts.backends.disk] Writing /home/selim/Documents/omniverse/data_gen/test-genene/_out_sdrec/occlusion_0146.npy
2024-05-27 19:43:50 [979,562ms] [Info] [omni.replicator.core.scripts.backends.disk] Writing /home/selim/Documents/omniverse/data_gen/test-genene/_out_sdrec/skeleton_0146.json
2024-05-27 19:43:50 [979,592ms] [Info] [omni.replicator.core.scripts.backends.disk] Writing /home/selim/Documents/omniverse/data_gen/test-genene/_out_sdrec/rgb_0146.png
I have no idea what the issue is, maybe I should remove the synthetic data recorder and reinstall??
