I have an issue in my OpenGL application because of a Device Removed event !!! Let me explain:
Issue happens only with a Dell laptop 5510 with Quadro M1000M (driver updated to 369.26) [EDIT: another laptop with Quadro M2000M is also reproducing the same issue].
It happens several times at the beginning and then it works fine.
The issue is random:
The display is not rendering any more, and I know that every OpenGL command is ok, except that SwapBuffers seems to fail (but without any error).
Only GDI drawing still working.
When it fails, I have just to resize the 3D window and it works ok !
BUT, I don’t know when the error is occurring because no OpenGL error occurs.
I have tried different settings with TDR registries.
I have tried the application with CodeXL: no error, except this strange Debug string: “D3D11: Removing Device.” This string occurs every time the issue coming and after that, when I resize the application, I have DLL unloading/loading message with “nvwgf2umx.dll”.
After searching on the web, it looks to be a DirectX error happening in my Nvidia driver (strange!).
The issue does not occur with laptop with Quadro M2000M (Optimus is disabled) and not on any other Quadro we have.
I am sure that the application is working with Nvidia adapter and not the Intel one.
The issue is not there when working with the Intel GPU.
I even try to catch myself the DXGI error with a own DirectX device and the SwapChain created on the same HWND I used for Opengl context. It works (!) but I don’t catch the error myself, even when using GetDeviceRemovedReason.
I have listed gpu adapters during the issue but no difference.
I don’t know what to do to detect the error myself. It’s frustrating because after that, the fix is very simple (just a dummy resize event and it’s works again). I searched since several days!
Any help ? Could you fix something in your opengl driver?
