Syncing Xavier with external device
Hello, I have Xavier board with Drive software 9.0 on it. I am trying to sync one Xavier with other device, where is Xaviare slave ande other device master, and I keep getting this log
sudo ./ptp4l -f ./gPTPSaploce_slave -p /dev/ptp0 -i eth0 -m -D
ptp4l[4122.102]: selected /dev/ptp0 as PTP clock
ptp4l[4122.102]: port 1: get_ts_info not supported
ptp4l[4122.144]: port 1: INITIALIZING to LISTENING on INITIALIZE
ptp4l[4122.144]: port 0: INITIALIZING to LISTENING on INITIALIZE
ptp4l[4122.157]: port 1: received PDELAY_REQ without timestamp
ptp4l[4122.172]: port 1: new foreign master 8a23fe.fffe.000005-0
ptp4l[4122.229]: selected best master clock 8a23fe.fffe.000005
ptp4l[4122.229]: foreign master not using PTP timescale
ptp4l[4122.229]: running in a temporal vortex
ptp4l[4122.229]: port 1: LISTENING to UNCALIBRATED on RS_SLAVE
ptp4l[4122.230]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.237]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.320]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.362]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.410]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.487]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.500]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.590]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.613]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.617]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.652]: master offset   -7241913 s0 freq +3398749 path delay   5863426
ptp4l[4122.657]: port 1: received PDELAY_REQ without timestamp
ptp4l[4122.680]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.682]: master offset   -7349562 s0 freq +3398749 path delay   5863426
ptp4l[4122.742]: master offset   -7484632 s1 freq +698697 path delay   5863426
ptp4l[4122.770]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.860]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.867]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.950]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.992]: port 1: received PDELAY_RESP without timestamp
ptp4l[4122.993]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.041]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.118]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.130]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.157]: port 1: received PDELAY_REQ without timestamp
ptp4l[4123.221]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.243]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.310]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.368]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.401]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.491]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.493]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.581]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.618]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.658]: port 1: received PDELAY_REQ without timestamp
ptp4l[4123.671]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.702]: master offset  -10195775 s2 freq -9497078 path delay   5856905
ptp4l[4123.703]: port 1: UNCALIBRATED to SLAVE on MASTER_CLOCK_SELECTED
ptp4l[4123.732]: master offset   -9964494 s2 freq -12324530 path delay   5856905
ptp4l[4123.743]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.761]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.762]: master offset   -9605108 s2 freq -14954492 path delay   5856905
ptp4l[4123.822]: master offset   -8716201 s2 freq -16947117 path delay   5856905
ptp4l[4123.851]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.853]: master offset   -8215360 s2 freq -19061137 path delay   5856905
ptp4l[4123.868]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.873]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.882]: master offset   -7652790 s2 freq -20963175 path delay   5856905
ptp4l[4123.941]: port 1: received PDELAY_RESP without timestamp
ptp4l[4123.943]: master offset   -6400033 s2 freq -22006255 path delay   5856905
ptp4l[4123.973]: master offset   -5742405 s2 freq -23268637 path delay   5856905
ptp4l[4123.998]: port 1: received PDELAY_RESP without timestamp
ptp4l[4124.003]: master offset   -5046326 s2 freq -24295279 path delay   5856905
ptp4l[4124.031]: port 1: received PDELAY_RESP without timestamp
ptp4l[4124.063]: master offset   -3591305 s2 freq -24354156 path delay   5856905
ptp4l[4124.093]: master offset   -2863413 s2 freq -24703655 path delay   5856905
ptp4l[4124.121]: port 1: received PDELAY_RESP without timestamp
ptp4l[4124.123]: master offset   -2121315 s2 freq -24820581 path delay   5856905
ptp4l[4124.123]: port 1: received PDELAY_RESP without timestamp
ptp4l[4124.158]: port 1: received PDELAY_REQ without timestamp
ptp4l[4124.183]: master offset   -2280838 s2 freq -25616499 path delay   5856905
ptp4l[4124.213]: master offset   -1654562 s2 freq -25674474 path delay   5856905
ptp4l[4124.243]: master offset    -885849 s2 freq -25402130 path delay   5856905
ptp4l[4124.248]: port 1: received PDELAY_RESP without timestamp
ptp4l[4124.253]: port 1: received PDELAY_RESP without timestamp
ptp4l[4124.301]: port 1: received PDELAY_RESP without timestamp
ptp4l[4124.303]: master offset     642952 s2 freq -24139084 path delay   5856905
ptp4l[4124.333]: master offset    1372264 s2 freq -23216886 path delay   5856905
ptp4l[4124.363]: master offset    2075298 s2 freq -22102173 path delay   5856905
ptp4l[4124.378]: port 1: received PDELAY_RESP without timestamp
ptp4l[4124.391]: port 1: received PDELAY_RESP without timestamp
ptp4l[4124.423]: master offset    3408984 s2 freq -20145897 path delay   5856905
ptp4l[4124.453]: master offset    4020562 s2 freq -18511624 path delay   5856905
ptp4l[4124.481]: port 1: received PDELAY_RESP without timestamp
And the time remains unsynced.
Hi Tegdif,
Please refer to the time sychronization use cases described in “Ethernet 100M/1G Networking” section of “NVIDIA DRIVE OS SDK Development Guide” below. Thanks!
https://docs.nvidia.com/drive/drive_os_5.1.6.1L/nvvib_docs/index.html#page/DRIVE_OS_Linux_SDK_Development_Guide/Network%20Setup/network_ethernet_100m_1g.html#wwpID0EPHA
Hi Tegdif,
Please confirm this answers your question so we can close the topic.
This was the page i was following the whole time. I found workaround: when i first start external device with master and then Xavier, syncing is happening.
Thank you for sharing back!
