Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.0.10363
other
Host Machine Version
native Ubuntu 18.04
other
we want to synchronize the Pegasus with an external device (Pegasus being the slave and the external device being the master).
So far we know, that the Pegasus uses PTP synchronization.
However, we are not sure how to setup the PTP synchronization on the Pegasus.
We are aware of the documentation Ethernet 100M/1G Networking (nvidia.com) , but we still need help.
In order to set the Pegasus as a slave for the external device, do we just have to execute the following command?
./ptp4l -f ./gPTP_slave.cfg -p /dev/ptp0 -i eth0 -m -D
Do we have to change anything in the gPTP_slave.cfg file?
Also, which port on the Pegasus board do we have to use for the PTP synchronization?
Once the PTP synchronization is successful, is the time on the Peagsus the same as on the master device?
