System cannot load dll files when start up Isaac sim
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: RTX 5080
  • Driver Version: 576.02 Game Ready
Topic Description
Detailed Description
System cannot load dll files when start up Isaac sim (also isaac-sim-comp-check)
Steps to Reproduce
directly run isaacsim
Error Messages
[Error] [carb] [Plugin: carb.profiler-gpu.plugin.dll] Could not load the dynamic library from i:/isaac/env_isaaclab/lib/site-packages/omni/kernel/plugins/carb.profiler-gpu.plugin.dll. Error: 鍔ㄦ€侀摼鎺ュ簱(DLL)鍒濆鍖栦緥绋嬪け璐ャ€?
(note that this may be caused by a dependent library)
[Warning] [carb] Potential plugin preload failed: i:/isaac/env_isaaclab/lib/site-packages/omni/kernel/plugins/carb.profiler-gpu.plugin.dll
[Info] [carb] Logging to file: C:/Users/Administrator/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250426_221413.log
2025-04-26 14:14:13 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn’t available.
[2.064s] [ext: omni.kit.async_engine-0.0.1] startup
[2.408s] [ext: omni.metrics.core-0.0.1] startup
2025-04-26 14:14:15 [2,383ms] [Error] [carb] [Plugin: carb.metrics.plugin.dll] Could not load the dynamic library from i:/isaac/env_isaaclab/lib/site-packages/isaacsim/extscache/omni.metrics.core-0.0.1+d02c707b.wx64.r/bin/deps/carb.metrics.plugin.dll. Error: 鍔ㄦ€侀摼鎺ュ簱(DLL)鍒濆鍖栦緥绋嬪け璐ャ€?
2025-04-26 14:14:15 [2,383ms] [Warning] [carb] Potential plugin preload failed: i:/isaac/env_isaaclab/lib/site-packages/isaacsim/extscache/omni.metrics.core-0.0.1+d02c707b.wx64.r/bin/deps/carb.metrics.plugin.dll
2025-04-26 14:14:15 [2,383ms] [Error] [omni.ext.plugin] [ext: omni.metrics.core-0.0.1] failed to load native plugin: i:/isaac/env_isaaclab/lib/site-packages/isaacsim/extscache/omni.metrics.core-0.0.1+d02c707b.wx64.r/bin/deps/carb.metrics.plugin.dll
[4.370s] [ext: omni.client.lib-1.0.0] startup
[4.433s] [ext: omni.blobkey-1.1.2] startup
2025-04-26 14:14:18 [4,611ms] [Error] [carb] [Plugin: omni.blobkey.plugin.dll] Could not load the dynamic library from i:/isaac/env_isaaclab/lib/site-packages/isaacsim/extscache/omni.blobkey-1.1.2+d02c707b.wx64.r/bin/deps/omni.blobkey.plugin.dll. Error: 鍔ㄦ€侀摼鎺ュ簱(DLL)鍒濆鍖栦緥绋嬪け璐ャ€?
2025-04-26 14:14:18 [4,612ms] [Warning] [carb] Potential plugin preload failed: i:/isaac/env_isaaclab/lib/site-packages/isaacsim/extscache/omni.blobkey-1.1.2+d02c707b.wx64.r/bin/deps/omni.blobkey.plugin.dll
2025-04-26 14:14:18 [4,612ms] [Error] [omni.ext.plugin] [ext: omni.blobkey-1.1.2] failed to load native plugin: i:/isaac/env_isaaclab/lib/site-packages/isaacsim/extscache/omni.blobkey-1.1.2+d02c707b.wx64.r/bin/deps/omni.blobkey.plugin.dll
[6.598s] [ext: omni.stats-1.0.1] startup
2025-04-26 14:14:20 [6,838ms] [Error] [carb] [Plugin: carb.stats.plugin.dll] Could not load the dynamic library from i:/isaac/env_isaaclab/lib/site-packages/isaacsim/extscache/omni.stats-1.0.1+d02c707b.wx64.r.cp310/bin/deps/carb.stats.plugin.dll. Error: 鍔ㄦ€侀摼鎺ュ簱(DLL)鍒濆鍖栦緥绋嬪け璐ャ€?
2025-04-26 14:14:20 [6,838ms] [Warning] [carb] Potential plugin preload failed: i:/isaac/env_isaaclab/lib/site-packages/isaacsim/extscache/omni.stats-1.0.1+d02c707b.wx64.r.cp310/bin/deps/carb.stats.plugin.dll
2025-04-26 14:14:20 [6,838ms] [Error] [omni.ext.plugin] [ext: omni.stats-1.0.1] failed to load native plugin: i:/isaac/env_isaaclab/lib/site-packages/isaacsim/extscache/omni.stats-1.0.1+d02c707b.wx64.r.cp310/bin/deps/carb.stats.plugin.dll
2025-04-26 14:14:21 [7,939ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.stats. Error: DLL load failed while importing stats: 鍔ㄦ€侀摼鎺ュ簱(DLL)鍒濆鍖栦緥绋嬪け璐ャ€? Traceback:
File “I:\Isaac\env_isaaclab\Lib\site-packages\omni\kernel\py\omni\ext_impl\custom_importer.py”, line 76, in import_module
return importlib.import_module(name)
File "C:\Users\Administrator\AppData\Local\Programs\Python\Python310\lib\importlib_init
.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1050, in _gcd_import
File “”, line 1027, in _find_and_load
File “”, line 1006, in _find_and_load_unlocked
File “”, line 688, in _load_unlocked
File “”, line 883, in exec_module
File “”, line 241, in _call_with_frames_removed
File “i:/isaac/env_isaaclab/lib/site-packages/isaacsim/extscache/omni.stats-1.0.1+d02c707b.wx64.r.cp310/omni/stats/init.py”, line 11, in
from ._stats import *
ImportError: DLL load failed while importing _stats: 鍔ㄦ€侀摼鎺ュ簱(DLL)鍒濆鍖栦緥绋嬪け璐ャ€?
2025-04-26 14:14:21 [7,939ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.stats’ in ‘i:\isaac\env_isaaclab\lib\site-packages\isaacsim\extscache\omni.stats-1.0.1+d02c707b.wx64.r.cp310’ failed to load.
At:
I:\Isaac\env_isaaclab\Lib\site-packages\omni\kernel\py\omni\ext_impl_internal.py(213): startup
I:\Isaac\env_isaaclab\Lib\site-packages\omni\kernel\py\omni\ext_impl_internal.py(328): startup_extension
PythonExtension.cpp::startup()(2):
I:\Isaac\env_isaaclab\lib\site-packages\omni\kit_app.py(119): startup
I:\Isaac\env_isaaclab\lib\site-packages\isaacsim_init_.py(161): main
I:\Isaac\env_isaaclab\Scripts\isaacsim.exe_main_.py(7):
C:\Users\Administrator\AppData\Local\Programs\Python\Python310\lib\runpy.py(86): _run_code
C:\Users\Administrator\AppData\Local\Programs\Python\Python310\lib\runpy.py(196): _run_module_as_main
2025-04-26 14:14:21 [7,939ms] [Error] [omni.ext.plugin] [ext: omni.stats-1.0.1] Failed to startup python extension.
Screenshots or Videos
Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
