System throttled due to over current
Version is Jetson_Linux_R35.4.1
When using YOLOv5, directly prompt system throttled due to over current
This isn’t an error to worry about. It’s just a message that says the clocks had their frequency reduced. There are two possible reasons:
  • If the Jetson is in its max performance mode, then it is to lower heat output when near its limits.
  • If the Jetson is in any other power mode, then it is a clock reduction to prevent exceeding that model’s current/power consumption (it honors battery life).
