hi
I am using MCX555A-ECAT and NVIDIA Mellanox SB7800.
Case1) What does the log below mean?
Jan 1 00:00:19 switch-db6306 health[3523]: [Health-ERR]: Health-Report: Power Supply 2/1 is unresponsive Aug 11 01:09:38 switch-db6306 rh19254 [web-ERR]: lib_ui_api_get_system_type(), lib_ui_api_utils.c:6 34, build 1: Error code 14000 (generic error) returned
Aug 11 01:09:38 switch-db6306 rh19254 [web-ERR]: Could not get system type, unsing[68], err[14000]
Aug 11 01:09:38 switch-db6306 rh19254 [web-ERR]: lib_ui_api_get_first_supported_chip type(), lib_ui_api_utils.c:691, build 1: Error code 14000 (generic error) returned
Aug 11 01:09:38 switch-db6306 rh19254 [web-ERR]: wcf_map_profile(), web_mtx_commands:c:1852, build 1: Er ror code 14000 (generic error) returned
Aug 11 01:09:38 switch-db6306 rh19254 [web-ERR]: web_include_template(), web_template.c:375, build 1:
Aug 11 01:09:38 switch-db6306 rh19254 [web-ERR]: Error in template "get-ports-info-system “at line 34 of the generated TCL code
Aug 11 01:09:38 switch-db6306 rh19254 [web-ERR]: web_render_template(), web_template.c:226, build 1: Errpr code 14002 (assertion failed) returned
Aug 11 01:09:38 switch-db6306 rh19254 [web-ERR]: main() , rh_main.c:337, build 1: Error code 14002 (assertion failed) returned
Aug 11 01:09:38 switch-db6306 rh19254 [web-ERR]: Request handler failed with error code 14002: assertion failed
Aug 11 05:08:26 switch-db6306 rh19254 [web-ERR]: ts_put_str_frag(), tstring.c 1679, build 1: Bail forced with error code 14011
Aug 11 05:08:26 switch-db6306 rh19254 [web-ERR]: ts_append_str_frag(), tstring.c:1381, build 1: Error code 14011 (buffer space exhausted)
Aug 11 :08:26 switch-db6306 rh19254 [web-ERR]: wlog_get_log_lines(), web_logging.c:291, build 1: Error code 14011
Aug 11 05:08:26 switch-db6306 rh19254 [web-ERR]: wlog_get_log_lines_cmd(), web_logging.c:384, build 1: Error code 14011
Aug 11 05:08:26 switch-db6306 rh19254 [web-ERR]: web_include_template(), web_template.c:375, build 1:
Aug 11 05:08:26 switch-db6306 rh19254 [web-ERR]: error in template " get-logs-duimp-file” aty line 52 of the generated TCL code
Aug 11 05:08:26 switch-db6306 rh19254 [web-ERR]: web_include_template(), web_template.c:226, build 1: Error code 14002
Aug 11 05:08:26 switch-db6306 rh19254 [web-ERR]: main(), rh_main.c:337, build 1: Error code 14002 (assertion failed) returned
Aug 11 05:08:26 switch-db6306 rh19254 [web-ERR]: Request handler failed with error code 14002: assertion failed
Case2) Intermittent data transmission/reception interruption occurs, and DCQCN-related Windows event logs occur at that time
Is there a correlation between the occurrence of DCQCN logs and data interruption?
Case3) Inquiry regarding Windows event log
Log)
ConnectX-5 firmware version 16.32.1010 is below the minimum FW version recommended this driver. Minimum recommended Firmware for this driver : 16.35.3502. It is recommended to upgrade the FW, for more details, please refer to WinOF-2 User Manual.
What error does this message mean?
Will the event log issue be improved by updating the firmware (16.32.1010 → 16.35.3502)?
