tegra multimedia api samples build
Hello
I am using jetpack 3.3 and I am trying to build the samples application under tegra_multimedia_api directory.
I am getting an error message indicating lack of some libraries.
Here is a screen shot:
[b]Make in samples/00_video_decode
  • make[1]: Entering directory ‘/home/nvidia/tegra_multimedia_api/samples/00_video_decode’
    Linking: video_decode
    /opt/install/bin/…/lib/gcc/aarch64-unknown-linux-gnu/4.8.5/…/…/…/…/aarch64-unknown-linux-gnu/bin/ld: cannot find -lnvinfer
    /opt/install/bin/…/lib/gcc/aarch64-unknown-linux-gnu/4.8.5/…/…/…/…/aarch64-unknown-linux-gnu/bin/ld: cannot find -lnvparsers
    collect2: error: ld returned 1 exit status
    Makefile:52: recipe for target ‘video_decode’ failed
    make[1]: *** [video_decode] Error 1
    make[1]: Leaving directory ‘/home/nvidia/tegra_multimedia_api/samples/00_video_decode’
    Makefile:52: recipe for target ‘all’ failed
    make: *** [all] Error 1
    nvidia@nvidia-ThinkPad-X240:~/tegra_multimedia_api$[/b]
    Eldad
  • Hi,
    We would suggest you install whole package through Jetpack3.3. It handles dependency of packages.
    Hello
    Thanks for the response. Still - using the installed Jetpack3.3 does not help.
    nvinfer and nvparsers are in TensorRT. Please check if you install the package.
    Or you may remove ‘-lnvinfer’ and ‘-lnvparses’ in
    tegra_multimedia_api\samples\Rules.mk
