Does anyone know if the Tegra NX PCIe (root port mode) supports the following:
Spread Spectrum = SSC
Common reference clock without SSC
Common reference clock with SSC
Separate reference clocks with SSC (SRIS) (already answered on these forums here)
Separate reference clocks without SSC (SRNS)
As well as knowing the default reference clock mode, I wish to know how to switch between them. There is some mention on the subject but it would be nice with something more official…
Umm actually on the NX I see now that the clocks are managed by the dedicated clock processor, which initialises the PLL E by device tree. The forum post here says I can put this into the bpmp-fw-dtb:
Are you sure “sudo ./flash -r -k bpmp-fw-dtb jetson-tx2 mmcblk0p1” is the flash command you used? I mean since this is NX, shouldn’t you be using “jetson-xavier-nx-devkit” (for SD card based board) and “jetson-xavier-nx-devkit-emmc.” (for emmc based board) instead of ‘jetson-tx2’??
Anyway, NX has two slots
M.2 Key-E slot which is owned by C4 controller and
M.2 Key-M slot which is owned by C5 controller
Both controllers (C4 and C5) have different PLL sources. So, if the spread needs to be disabled for C4 then, please apply the following patch
I wrote jetson-tx2 in the flash command as a reference to the similar question for the X2. Sorry for the confusion. I am using the correct command in the lab.
I will try out these modifications tomorrow and report the results.
We have modified the bpmp device tree to disable SSC. Thank you for this info. We are able to measure with oscilloscope that the spread is gone.
We have now done a simple test in SRNS mode - that is, root port (NX) talks with a generic endpoint without propagating the refclk. This seems to be successful and we are able to communicate with the endpoint.
Sorry to bother you with this, but is it possible for Nvidia to comment whether there is any risk involved in using the Tegra NX in SRNS mode? I assume this is not officially supported on your side.
Yes. you are correct that this is not officially supported.
Reasons being since the same PLL is used for both USB and PCIe and USB certification needs spread to be enabled, if you don’t care about USB much (i.e. the certification part) and ok to have any EMI issues that might come because of spread being disabled, then, it is ok to keep the spread disabled.
Again thanks for quick reply - we are OK with spread being disabled -
BUT the actual question is: does Nvidia officially support that the root port (NX) and endpoint work with independent 100 MHz reference clocks?
I.e.
[100 MHz refclk, no SSC] —> NX(RP) <— PCIe cabling without refclk —> ENDPOINT <— [100 MHz refclk, no SSC]
This is basically SRNS. Separate reference clocks without SSC.
For anyone that needs to do this on their NX kits (or similar):
Vidyas patches are from a git repo we do not have access to. So what you need to do:
Pay attention to the #include directive in the patch. While I cannot find <mach-t194/clk-t194.h>, I can find the clock id - TEGRA194_CLK_PLLNVHS by just grepping through everything after doing source_sync.sh. Use the clock ID from there and mind that you use the same clock ID that is for the L4T version you are using. E.g. source_sync.sh -d <YOUR_L4T_VERSION>, then “find . -type f -exec grep TEGRA194_CLK_PLLNVHS {} ;”
Then you device-tree-decompile the relevant bpmp in your Linux_for_Tegra folder (where flash.sh resides. For example:
If you do sudo ./flash.sh -r jetson-xavier-nx-devkit-emmc mmcblk0p1:
Then look at the jetson-xavier-nx-devkit-emmc.conf
Compile back to dtb and copy these back
dtc -o test.dtb test.dts
cp test.dtb ./bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb
cp test.dtb ./bootloader/tegra194-a02-bpmp-p3668-a00.dtb
Noting I needed sudo in front of one of these.
Then flash the entire kit.
Note that we have verified the SSC off using oscilloscope.
Usually, it should work but to answer your question, Yes, Nvidia doesn’t support this configuration officially.
Please note that it is possible to get AER corrected errors if any of the ASPM states are enabled.
