Hello, everyone:
I’m currently debugging a custom kernel on a Tx2Nx board, and I found the following message when I was looking at the kernel print from dmesg, and I was wondering if this is problematic and what I should do to fix it, and I’m currently using version 32.7.3, 4.9.299-rt191+.
[ 0.470029] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.470093] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.470106] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.470108] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.470111] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.470273] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.470284] tegra-pmc c360000.pmc: WARNING: IO pad defaults is supported via pinctrl
[ 0.470319] ------------[ cut here ]------------
[ 0.470331] WARNING: CPU: 0 PID: 1 at /home/huanglielie/Jetson/JetsonLinux32.7.3/kernel/nvidia/drivers/padctrl/padctrl-tegra-io-pads.c:247 tegra_io_pads_padctrl_init+0xb4/0x110
[ 0.470333] Modules linked in:
[ 0.470343] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.9.299-rt191+ #493
[ 0.470346] Hardware name: lanai-3636 (DT)
[ 0.470349] task: ffffffc0f0f18000 task.stack: ffffffc0f0e34000
[ 0.470353] PC is at tegra_io_pads_padctrl_init+0xb4/0x110
[ 0.470356] LR is at tegra_io_pads_padctrl_init+0xb4/0x110
[ 0.470360] pc : [] lr : [] pstate: 40400045
[ 0.470362] sp : ffffffc0f0e379e0
[ 0.470364] x29: ffffffc0f0e379e0 x28: ffffff8009848890
[ 0.470370] x27: ffffff800a1a75f0 x26: ffffff8009008a08
[ 0.470376] x25: 0000000000000000 x24: 0000000000000000
[ 0.470381] x23: ffffff8009f4c000 x22: ffffffc0ef8e0c10
[ 0.470386] x21: ffffffc0efe5c000 x20: ffffffc0efe5d058
[ 0.470391] x19: ffffffc0ef8e0c10 x18: 0000000000000000
[ 0.470396] x17: 0000000000000002 x16: 0000000000000000
[ 0.470401] x15: ffffffffffffffff x14: 6169762064657472
[ 0.470406] x13: 6f70707573207369 x12: 0000000000000000
[ 0.470410] x11: 0000000000000004 x10: 0000000000000089
[ 0.470415] x9 : 57203a636d702e30 x8 : ffffffc0f704494b
[ 0.470420] x7 : 0000000000000000 x6 : 0000000000000001
[ 0.470425] x5 : 0000000000000000 x4 : 0000000000000000
[ 0.470430] x3 : ffffffffffffffff x2 : ffffff8009e93388
[ 0.470434] x1 : ffffffc0f0f18000 x0 : 0000000000000048
[ 0.470441] —[ end trace 0000000000000001 ]—
[ 0.470443] Call trace:
[ 0.470448] [] tegra_io_pads_padctrl_init+0xb4/0x110
[ 0.470453] [] tegra_pmc_probe+0x764/0xc30
[ 0.470460] [] platform_drv_probe+0x60/0xc0
[ 0.470464] [] driver_probe_device+0x29c/0x450
[ 0.470468] [] __device_attach_driver+0xa8/0x148
[ 0.470472] [] bus_for_each_drv+0x58/0xa8
[ 0.470476] [] __device_attach+0xc8/0x158
[ 0.470480] [] device_initial_probe+0x24/0x30
[ 0.470484] [] bus_probe_device+0x9c/0xa8
[ 0.470487] [] device_add+0x3d0/0x5d8
[ 0.470493] [] of_device_add+0x40/0x50
[ 0.470496] [] of_platform_device_create_pdata+0x9c/0x100
[ 0.470499] [] of_platform_bus_create+0x104/0x468
[ 0.470503] [] of_platform_populate+0x8c/0x140
[ 0.470510] [] of_platform_default_populate_init+0x68/0x7c
[ 0.470515] [] do_one_initcall+0x44/0x130
[ 0.470520] [] kernel_init_freeable+0x1e8/0x28c
[ 0.470525] [] kernel_init+0x18/0x108
[ 0.470529] [] ret_from_fork+0x10/0x30
In the meantime, I’ll provide the full log in the attachment.
