Pinmux-dts2cfg.py get errors
Hello everyone:
I have to generate a cfg file used pinmux-dts2cfg.py,but get some errors:
python pinmux-dts2cfg.py --pinmux addr_info.txt gpio_addr_info.txt por_val.txt --mandatory_pinmux_file mandatory_pinmux.txt tegra19x-jetson_xavier_nx_module-pinmux.dtsi tegra19x-jetson_xavier_nx_module-gpio-default.dtsi 1.0 > tegra19x-mb1-pinmux-p3668-a01.cfg
ERROR: pin eqos_rd3_pf1(0x00022470) field nvidia,lpbk(0x00000020) is not matching, val = 0x01 expected = 0x00
ERROR: pin eqos_sma_mdio_pf4(0x00022440) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin sdmmc4_cmd(0x00002440) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin soc_gpio10_pg6(0x00000410) field nvidia,tristate(0x00000010) is not matching, val = 0x01 expected = 0x00
ERROR: pin gp_pwm2_px2(0x00000410) field nvidia,tristate(0x00000010) is not matching, val = 0x01 expected = 0x00
ERROR: pin uart2_tx_px4(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart2_rx_px5(0x00000450) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin can0_dout_paa2(0x0000c400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin can0_din_paa3(0x0000c450) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart3_tx_pcc5(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart3_rx_pcc6(0x00000450) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart1_tx_pr2(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart1_rx_pr3(0x00000454) field nvidia,pull(0x0000000c) is not matching, val = 0x01 expected = 0x02
here are the dts files:
  • tegra19x-jetson_xavier_nx_module-gpio-default.dtsi:
    /*This dtsi file was generated by jetson_xavier_nx_module.xlsm Revision: 1.06 /
    • Copyright (c) 2017, NVIDIA CORPORATION. All rights reserved.
    • This program is free software; you can redistribute it and/or modify
    • it under the terms of the GNU General Public License as published by
    • the Free Software Foundation; either version 2 of the License, or
    • (at your option) any later version.
    • This program is distributed in the hope that it will be useful, but WITHOUT
    • ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    • FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
    • more details.
    #include <dt-bindings/gpio/tegra-gpio.h>
    gpio@2200000 {
    gpio-init-names = “default”;
    gpio-init-0 = <&gpio_default>;
      	gpio_default: default {
      		gpio-input = <
      			TEGRA_GPIO(S, 7)
      			TEGRA_GPIO(G, 0)
      			TEGRA_GPIO(G, 4)
      			TEGRA_GPIO(G, 7)
      			TEGRA_GPIO(H, 3)
      			TEGRA_GPIO(H, 5)
      			TEGRA_GPIO(Y, 0)
      			TEGRA_GPIO(Y, 1)
      			TEGRA_GPIO(Y, 2)
      			TEGRA_GPIO(Y, 3)
      			TEGRA_GPIO(Y, 4)
      			TEGRA_GPIO(Y, 5)
      			TEGRA_GPIO(Y, 7)
      			TEGRA_GPIO(Z, 1)
      			TEGRA_GPIO(Z, 3)
      			TEGRA_GPIO(Z, 4)
      			TEGRA_GPIO(Z, 5)
      			TEGRA_GPIO(Z, 6)
      			TEGRA_GPIO(Z, 7)
      			TEGRA_GPIO(EE, 0)
      			TEGRA_GPIO(EE, 4)
      			TEGRA_GPIO(CC, 4)
      			TEGRA_GPIO(Q, 1)
      			TEGRA_GPIO(Q, 2)
      			TEGRA_GPIO(Q, 3)
      			TEGRA_GPIO(Q, 5)
      			TEGRA_GPIO(Q, 6)
      			TEGRA_GPIO(R, 0)
      			TEGRA_GPIO(R, 4)
      			TEGRA_GPIO(R, 5)
      			TEGRA_GPIO(L, 2)
      			TEGRA_GPIO(N, 1)
      		gpio-output-low = <
      			TEGRA_GPIO(G, 2)
      			TEGRA_GPIO(X, 0)
      			TEGRA_GPIO(AA, 5)
      			TEGRA_GPIO(CC, 0)
      			TEGRA_GPIO(CC, 2)
      			TEGRA_GPIO(CC, 3)
      			TEGRA_GPIO(P, 4)
      			TEGRA_GPIO(P, 5)
      			TEGRA_GPIO(B, 0)
      		gpio-output-high = <
      			TEGRA_GPIO(CC, 1)
  • tegra19x-jetson_xavier_nx_module-padvoltage-default.dtsi
    • more details.
    pmc@c360000 {
    io-pad-defaults {
    sdmmc1_hv {
    nvidia,io-pad-init-voltage = <IO_PAD_VOLTAGE_3_3V>;
      		sdmmc3_hv {
      		eqos {
      			nvidia,io-pad-init-voltage = <IO_PAD_VOLTAGE_1_8V>;
      		qspi {
      		debug {
      		ao_hv {
      		audio_hv {
      			nvidia,io-pad-init-voltage = <IO_PAD_VOLTAGE_OFF>;
      		ufs {
  • tegra19x-jetson_xavier_nx_module-pinmux.dtsi
    • more details.
    #include <dt-bindings/pinctrl/pinctrl-tegra.h>
    pinmux@2430000 {
    pinctrl-names = “default”, “drive”, “unused”;
    pinctrl-0 = <&pinmux_default>;
    pinctrl-1 = <&drive_default>;
    pinctrl-2 = <&pinmux_unused_lowpower>;
      	pinmux_default: common {
      		/* SFIO Pin Configuration */
      		dap5_sclk_pt5 {
      			nvidia,pins = "dap5_sclk_pt5";
      			nvidia,function = "i2s5";
      			nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
      			nvidia,tristate = <TEGRA_PIN_DISABLE>;
      			nvidia,enable-input = <TEGRA_PIN_DISABLE>;
      			nvidia,lpdr = <TEGRA_PIN_DISABLE>;
      		dap5_dout_pt6 {
      			nvidia,pins = "dap5_dout_pt6";
      		dap5_fs_pu0 {
      			nvidia,pins = "dap5_fs_pu0";
      		sdmmc1_clk_pj0 {
      			nvidia,pins = "sdmmc1_clk_pj0";
      			nvidia,function = "sdmmc1";
      			nvidia,pull = <TEGRA_PIN_PULL_NONE>;
      			nvidia,enable-input = <TEGRA_PIN_ENABLE>;
      			nvidia,loopback = <TEGRA_PIN_ENABLE>;
      		sdmmc1_cmd_pj1 {
      			nvidia,pins = "sdmmc1_cmd_pj1";
      			nvidia,pull = <TEGRA_PIN_PULL_UP>;
      		sdmmc1_dat0_pj2 {
      			nvidia,pins = "sdmmc1_dat0_pj2";
      		sdmmc1_dat1_pj3 {
      			nvidia,pins = "sdmmc1_dat1_pj3";
      		sdmmc1_dat2_pj4 {
      			nvidia,pins = "sdmmc1_dat2_pj4";
      		sdmmc1_dat3_pj5 {
      			nvidia,pins = "sdmmc1_dat3_pj5";
      		sdmmc3_clk_po0 {
      			nvidia,pins = "sdmmc3_clk_po0";
      			nvidia,function = "sdmmc3";
      		sdmmc3_cmd_po1 {
      			nvidia,pins = "sdmmc3_cmd_po1";
      		sdmmc3_dat0_po2 {
      			nvidia,pins = "sdmmc3_dat0_po2";
      		sdmmc3_dat1_po3 {
      			nvidia,pins = "sdmmc3_dat1_po3";
      		sdmmc3_dat2_po4 {
      			nvidia,pins = "sdmmc3_dat2_po4";
      		sdmmc3_dat3_po5 {
      			nvidia,pins = "sdmmc3_dat3_po5";
      		eqos_txc_pe0 {
      			nvidia,pins = "eqos_txc_pe0";
      			nvidia,function = "eqos";
      		eqos_td0_pe1 {
      			nvidia,pins = "eqos_td0_pe1";
      		eqos_td1_pe2 {
      			nvidia,pins = "eqos_td1_pe2";
      		eqos_td2_pe3 {
      			nvidia,pins = "eqos_td2_pe3";
      		eqos_td3_pe4 {
      			nvidia,pins = "eqos_td3_pe4";
      		eqos_tx_ctl_pe5 {
      			nvidia,pins = "eqos_tx_ctl_pe5";
      		eqos_rd0_pe6 {
      			nvidia,pins = "eqos_rd0_pe6";
      			nvidia,tristate = <TEGRA_PIN_ENABLE>;
      		eqos_rd1_pe7 {
      			nvidia,pins = "eqos_rd1_pe7";
      		eqos_rd2_pf0 {
      			nvidia,pins = "eqos_rd2_pf0";
      		eqos_rd3_pf1 {
      			nvidia,pins = "eqos_rd3_pf1";
      		eqos_rx_ctl_pf2 {
      			nvidia,pins = "eqos_rx_ctl_pf2";
      		eqos_rxc_pf3 {
      			nvidia,pins = "eqos_rxc_pf3";
      		eqos_sma_mdio_pf4 {
      			nvidia,pins = "eqos_sma_mdio_pf4";
      		eqos_sma_mdc_pf5 {
      			nvidia,pins = "eqos_sma_mdc_pf5";
      		qspi0_sck_pc0 {
      			nvidia,pins = "qspi0_sck_pc0";
      			nvidia,function = "qspi0";
      		qspi0_cs_n_pc1 {
      			nvidia,pins = "qspi0_cs_n_pc1";
      		qspi0_io0_pc2 {
      			nvidia,pins = "qspi0_io0_pc2";
      		qspi0_io1_pc3 {
      			nvidia,pins = "qspi0_io1_pc3";
      		qspi0_io2_pc4 {
      			nvidia,pins = "qspi0_io2_pc4";
      		qspi0_io3_pc5 {
      			nvidia,pins = "qspi0_io3_pc5";
      		sdmmc4_clk {
      			nvidia,pins = "sdmmc4_clk";
      			nvidia,function = "sdmmc4";
      		sdmmc4_cmd {
      			nvidia,pins = "sdmmc4_cmd";
      		sdmmc4_dat0 {
      			nvidia,pins = "sdmmc4_dat0";
      		sdmmc4_dat1 {
      			nvidia,pins = "sdmmc4_dat1";
      		sdmmc4_dat2 {
      			nvidia,pins = "sdmmc4_dat2";
      		sdmmc4_dat3 {
      			nvidia,pins = "sdmmc4_dat3";
      		sdmmc4_dat4 {
      			nvidia,pins = "sdmmc4_dat4";
      		sdmmc4_dat5 {
      			nvidia,pins = "sdmmc4_dat5";
      		sdmmc4_dat6 {
      			nvidia,pins = "sdmmc4_dat6";
      		sdmmc4_dat7 {
      			nvidia,pins = "sdmmc4_dat7";
      		sdmmc4_dqs {
      			nvidia,pins = "sdmmc4_dqs";
      		soc_gpio10_pg6 {
      			nvidia,pins = "soc_gpio10_pg6";
      			nvidia,function = "gp";
      		soc_gpio13_ph1 {
      			nvidia,pins = "soc_gpio13_ph1";
      		gen1_i2c_scl_pi3 {
      			nvidia,pins = "gen1_i2c_scl_pi3";
      			nvidia,function = "i2c1";
      			nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
      			nvidia,lpdr = <TEGRA_PIN_ENABLE>;
      		gen1_i2c_sda_pi4 {
      			nvidia,pins = "gen1_i2c_sda_pi4";
      		gp_pwm2_px2 {
      			nvidia,pins = "gp_pwm2_px2";
      		uart2_tx_px4 {
      			nvidia,pins = "uart2_tx_px4";
      			nvidia,function = "uartb";
      		uart2_rx_px5 {
      			nvidia,pins = "uart2_rx_px5";
      		uart2_rts_px6 {
      			nvidia,pins = "uart2_rts_px6";
      		uart2_cts_px7 {
      			nvidia,pins = "uart2_cts_px7";
      		shutdown_n {
      			nvidia,pins = "shutdown_n";
      			nvidia,function = "shutdown";
      		vcomp_alert_pee1 {
      			nvidia,pins = "vcomp_alert_pee1";
      			nvidia,function = "soc";
      		pwr_i2c_scl_pee5 {
      			nvidia,pins = "pwr_i2c_scl_pee5";
      			nvidia,function = "i2c5";
      		pwr_i2c_sda_pee6 {
      			nvidia,pins = "pwr_i2c_sda_pee6";
      		batt_oc_pee3 {
      			nvidia,pins = "batt_oc_pee3";
      		can0_dout_paa2 {
      			nvidia,pins = "can0_dout_paa2";
      			nvidia,function = "can0";
      		can0_din_paa3 {
      			nvidia,pins = "can0_din_paa3";
      		uart3_tx_pcc5 {
      			nvidia,pins = "uart3_tx_pcc5";
      			nvidia,function = "uartc";
      		uart3_rx_pcc6 {
      			nvidia,pins = "uart3_rx_pcc6";
      		gen2_i2c_scl_pcc7 {
      			nvidia,pins = "gen2_i2c_scl_pcc7";
      			nvidia,function = "i2c2";
      			nvidia,io-high-voltage = <TEGRA_PIN_ENABLE>;
      		gen2_i2c_sda_pdd0 {
      			nvidia,pins = "gen2_i2c_sda_pdd0";
      		gen8_i2c_scl_pdd1 {
      			nvidia,pins = "gen8_i2c_scl_pdd1";
      			nvidia,function = "i2c8";
      		gen8_i2c_sda_pdd2 {
      			nvidia,pins = "gen8_i2c_sda_pdd2";
      		extperiph1_clk_pp0 {
      			nvidia,pins = "extperiph1_clk_pp0";
      			nvidia,function = "extperiph1";
      		extperiph2_clk_pp1 {
      			nvidia,pins = "extperiph2_clk_pp1";
      			nvidia,function = "extperiph2";
      		cam_i2c_scl_pp2 {
      			nvidia,pins = "cam_i2c_scl_pp2";
      			nvidia,function = "i2c3";
      		cam_i2c_sda_pp3 {
      			nvidia,pins = "cam_i2c_sda_pp3";
      		soc_gpio07_pp7 {
      			nvidia,pins = "soc_gpio07_pp7";
      		uart1_tx_pr2 {
      			nvidia,pins = "uart1_tx_pr2";
      			nvidia,function = "uarta";
      		uart1_rx_pr3 {
      			nvidia,pins = "uart1_rx_pr3";
      		pex_l4_clkreq_n_pl0 {
      			nvidia,pins = "pex_l4_clkreq_n_pl0";
      			nvidia,function = "pe4";
      		pex_l4_rst_n_pl1 {
      			nvidia,pins = "pex_l4_rst_n_pl1";
      		pex_l5_clkreq_n {
      			nvidia,pins = "pex_l5_clkreq_n";
      			nvidia,function = "pe5";
      		pex_l5_rst_n {
      			nvidia,pins = "pex_l5_rst_n";
      		dp_aux_ch0_hpd_pm0 {
      			nvidia,pins = "dp_aux_ch0_hpd_pm0";
      			nvidia,function = "dp";
      		dp_aux_ch1_hpd_pm1 {
      			nvidia,pins = "dp_aux_ch1_hpd_pm1";
      		hdmi_cec_pm4 {
      			nvidia,pins = "hdmi_cec_pm4";
      			nvidia,function = "hdmi";
      		/* GPIO Pin Configuration */
      		aud_mclk_ps4 {
      			nvidia,pins = "aud_mclk_ps4";
      			nvidia,function = "rsvd1";
      		soc_gpio32_ps7 {
      			nvidia,pins = "soc_gpio32_ps7";
      			nvidia,function = "rsvd0";
      		dap3_sclk_pt1 {
      			nvidia,pins = "dap3_sclk_pt1";
      			nvidia,function = "rsvd2";
      		dap3_dout_pt2 {
      			nvidia,pins = "dap3_dout_pt2";
      		dap3_din_pt3 {
      			nvidia,pins = "dap3_din_pt3";
      		dap3_fs_pt4 {
      			nvidia,pins = "dap3_fs_pt4";
      		dap5_din_pt7 {
      			nvidia,pins = "dap5_din_pt7";
      			nvidia,function = "rsvd3";
      		soc_gpio00_pg0 {
      			nvidia,pins = "soc_gpio00_pg0";
      		soc_gpio02_pg2 {
      			nvidia,pins = "soc_gpio02_pg2";
      		soc_gpio08_pg4 {
      			nvidia,pins = "soc_gpio08_pg4";
      		soc_gpio11_pg7 {
      			nvidia,pins = "soc_gpio11_pg7";
      		uart4_tx_ph3 {
      			nvidia,pins = "uart4_tx_ph3";
      		uart4_rts_ph5 {
      			nvidia,pins = "uart4_rts_ph5";
      		gpu_pwr_req_px0 {
      			nvidia,pins = "gpu_pwr_req_px0";
      		spi3_sck_py0 {
      			nvidia,pins = "spi3_sck_py0";
      		spi3_miso_py1 {
      			nvidia,pins = "spi3_miso_py1";
      		spi3_mosi_py2 {
      			nvidia,pins = "spi3_mosi_py2";
      		spi3_cs0_py3 {
      			nvidia,pins = "spi3_cs0_py3";
      		spi3_cs1_py4 {
      			nvidia,pins = "spi3_cs1_py4";
      		uart5_tx_py5 {
      			nvidia,pins = "uart5_tx_py5";
      		uart5_rts_py7 {
      			nvidia,pins = "uart5_rts_py7";
      		usb_vbus_en0_pz1 {
      			nvidia,pins = "usb_vbus_en0_pz1";
      		spi1_sck_pz3 {
      			nvidia,pins = "spi1_sck_pz3";
      		spi1_miso_pz4 {
      			nvidia,pins = "spi1_miso_pz4";
      		spi1_mosi_pz5 {
      			nvidia,pins = "spi1_mosi_pz5";
      		spi1_cs0_pz6 {
      			nvidia,pins = "spi1_cs0_pz6";
      		spi1_cs1_pz7 {
      			nvidia,pins = "spi1_cs1_pz7";
      		safe_state_pee0 {
      			nvidia,pins = "safe_state_pee0";
      		power_on_pee4 {
      			nvidia,pins = "power_on_pee4";
      		can0_en_paa5 {
      			nvidia,pins = "can0_en_paa5";
      		spi2_sck_pcc0 {
      			nvidia,pins = "spi2_sck_pcc0";
      		spi2_miso_pcc1 {
      			nvidia,pins = "spi2_miso_pcc1";
      		spi2_mosi_pcc2 {
      			nvidia,pins = "spi2_mosi_pcc2";
      		spi2_cs0_pcc3 {
      			nvidia,pins = "spi2_cs0_pcc3";
      		touch_clk_pcc4 {
      			nvidia,pins = "touch_clk_pcc4";
      		soc_gpio04_pp4 {
      			nvidia,pins = "soc_gpio04_pp4";
      		soc_gpio05_pp5 {
      			nvidia,pins = "soc_gpio05_pp5";
      		soc_gpio21_pq1 {
      			nvidia,pins = "soc_gpio21_pq1";
      		soc_gpio22_pq2 {
      			nvidia,pins = "soc_gpio22_pq2";
      		soc_gpio23_pq3 {
      			nvidia,pins = "soc_gpio23_pq3";
      		soc_gpio40_pq4 {
      			nvidia,pins = "soc_gpio40_pq4";
      		soc_gpio41_pq5 {
      			nvidia,pins = "soc_gpio41_pq5";
      		soc_gpio42_pq6 {
      			nvidia,pins = "soc_gpio42_pq6";
      		soc_gpio43_pq7 {
      			nvidia,pins = "soc_gpio43_pq7";
      		soc_gpio44_pr0 {
      			nvidia,pins = "soc_gpio44_pr0";
      		soc_gpio45_pr1 {
      			nvidia,pins = "soc_gpio45_pr1";
      		uart1_rts_pr4 {
      			nvidia,pins = "uart1_rts_pr4";
      		uart1_cts_pr5 {
      			nvidia,pins = "uart1_cts_pr5";
      		cpu_pwr_req_0_pb0 {
      			nvidia,pins = "cpu_pwr_req_0_pb0";
      		pex_wake_n_pl2 {
      			nvidia,pins = "pex_wake_n_pl2";
      		soc_gpio54_pn1 {
      			nvidia,pins = "soc_gpio54_pn1";
      	pinmux_unused_lowpower: unused_lowpower {
      		dap1_sclk_ps0 {
      			nvidia,pins = "dap1_sclk_ps0";
      		dap1_dout_ps1 {
      			nvidia,pins = "dap1_dout_ps1";
      		dap1_din_ps2 {
      			nvidia,pins = "dap1_din_ps2";
      		dap1_fs_ps3 {
      			nvidia,pins = "dap1_fs_ps3";
      		soc_gpio30_ps5 {
      			nvidia,pins = "soc_gpio30_ps5";
      		soc_gpio31_ps6 {
      			nvidia,pins = "soc_gpio31_ps6";
      		soc_gpio33_pt0 {
      			nvidia,pins = "soc_gpio33_pt0";
      		qspi1_sck_pc6 {
      			nvidia,pins = "qspi1_sck_pc6";
      		qspi1_cs_n_pc7 {
      			nvidia,pins = "qspi1_cs_n_pc7";
      		qspi1_io0_pd0 {
      			nvidia,pins = "qspi1_io0_pd0";
      		qspi1_io1_pd1 {
      			nvidia,pins = "qspi1_io1_pd1";
      		qspi1_io2_pd2 {
      			nvidia,pins = "qspi1_io2_pd2";
      		qspi1_io3_pd3 {
      			nvidia,pins = "qspi1_io3_pd3";
      		soc_gpio01_pg1 {
      			nvidia,pins = "soc_gpio01_pg1";
      		soc_gpio03_pg3 {
      			nvidia,pins = "soc_gpio03_pg3";
      		soc_gpio09_pg5 {
      			nvidia,pins = "soc_gpio09_pg5";
      		soc_gpio12_ph0 {
      			nvidia,pins = "soc_gpio12_ph0";
      		soc_gpio14_ph2 {
      			nvidia,pins = "soc_gpio14_ph2";
      		uart4_rx_ph4 {
      			nvidia,pins = "uart4_rx_ph4";
      		uart4_cts_ph6 {
      			nvidia,pins = "uart4_cts_ph6";
      		dap2_sclk_ph7 {
      			nvidia,pins = "dap2_sclk_ph7";
      		dap2_dout_pi0 {
      			nvidia,pins = "dap2_dout_pi0";
      		dap2_din_pi1 {
      			nvidia,pins = "dap2_din_pi1";
      		dap2_fs_pi2 {
      			nvidia,pins = "dap2_fs_pi2";
      		cv_pwr_req_px1 {
      			nvidia,pins = "cv_pwr_req_px1";
      		gp_pwm3_px3 {
      			nvidia,pins = "gp_pwm3_px3";
      		uart5_rx_py6 {
      			nvidia,pins = "uart5_rx_py6";
      		uart5_cts_pz0 {
      			nvidia,pins = "uart5_cts_pz0";
      		usb_vbus_en1_pz2 {
      			nvidia,pins = "usb_vbus_en1_pz2";
      		ao_retention_n_pee2 {
      			nvidia,pins = "ao_retention_n_pee2";
      		can1_dout_paa0 {
      			nvidia,pins = "can1_dout_paa0";
      		can1_din_paa1 {
      			nvidia,pins = "can1_din_paa1";
      		can0_stb_paa4 {
      			nvidia,pins = "can0_stb_paa4";
      		can0_wake_paa6 {
      			nvidia,pins = "can0_wake_paa6";
      		can0_err_paa7 {
      			nvidia,pins = "can0_err_paa7";
      		can1_stb_pbb0 {
      			nvidia,pins = "can1_stb_pbb0";
      		can1_en_pbb1 {
      			nvidia,pins = "can1_en_pbb1";
      		can1_wake_pbb2 {
      			nvidia,pins = "can1_wake_pbb2";
      		can1_err_pbb3 {
      			nvidia,pins = "can1_err_pbb3";
      		soc_gpio06_pp6 {
      			nvidia,pins = "soc_gpio06_pp6";
      		soc_gpio20_pq0 {
      			nvidia,pins = "soc_gpio20_pq0";
      		dap6_sclk_pa0 {
      			nvidia,pins = "dap6_sclk_pa0";
      		dap6_dout_pa1 {
      			nvidia,pins = "dap6_dout_pa1";
      		dap6_din_pa2 {
      			nvidia,pins = "dap6_din_pa2";
      		dap6_fs_pa3 {
      			nvidia,pins = "dap6_fs_pa3";
      		dap4_sclk_pa4 {
      			nvidia,pins = "dap4_sclk_pa4";
      		dap4_dout_pa5 {
      			nvidia,pins = "dap4_dout_pa5";
      		dap4_din_pa6 {
      			nvidia,pins = "dap4_din_pa6";
      		dap4_fs_pa7 {
      			nvidia,pins = "dap4_fs_pa7";
      		cpu_pwr_req_1_pb1 {
      			nvidia,pins = "cpu_pwr_req_1_pb1";
      		ufs0_ref_clk_pff0 {
      			nvidia,pins = "ufs0_ref_clk_pff0";
      		ufs0_rst_pff1 {
      			nvidia,pins = "ufs0_rst_pff1";
      		pex_l0_clkreq_n_pk0 {
      			nvidia,pins = "pex_l0_clkreq_n_pk0";
      		pex_l0_rst_n_pk1 {
      			nvidia,pins = "pex_l0_rst_n_pk1";
      		pex_l1_clkreq_n_pk2 {
      			nvidia,pins = "pex_l1_clkreq_n_pk2";
      		pex_l1_rst_n_pk3 {
      			nvidia,pins = "pex_l1_rst_n_pk3";
      		pex_l2_clkreq_n_pk4 {
      			nvidia,pins = "pex_l2_clkreq_n_pk4";
      		pex_l2_rst_n_pk5 {
      			nvidia,pins = "pex_l2_rst_n_pk5";
      		pex_l3_clkreq_n_pk6 {
      			nvidia,pins = "pex_l3_clkreq_n_pk6";
      		pex_l3_rst_n_pk7 {
      			nvidia,pins = "pex_l3_rst_n_pk7";
      		sata_dev_slp_pl3 {
      			nvidia,pins = "sata_dev_slp_pl3";
      		dp_aux_ch2_hpd_pm2 {
      			nvidia,pins = "dp_aux_ch2_hpd_pm2";
      		dp_aux_ch3_hpd_pm3 {
      			nvidia,pins = "dp_aux_ch3_hpd_pm3";
      		soc_gpio50_pm5 {
      			nvidia,pins = "soc_gpio50_pm5";
      		soc_gpio51_pm6 {
      			nvidia,pins = "soc_gpio51_pm6";
      		soc_gpio52_pm7 {
      			nvidia,pins = "soc_gpio52_pm7";
      		soc_gpio53_pn0 {
      			nvidia,pins = "soc_gpio53_pn0";
      		soc_gpio55_pn2 {
      			nvidia,pins = "soc_gpio55_pn2";
      	drive_default: drive {
Hi suen,
The “–mandatory_pinmux_file” is optional , it is mentioned in the README file.
Please try without --mandatory_pinmux_file mandatory_pinmux.txt
$python pinmux-dts2cfg.py --pinmux addr_info.txt gpio_addr_info.txt por_val.txt tegra19x-jetson_xavier_nx_module-pinmux.dtsi tegra19x-jetson_xavier_nx_module-gpio-default.dtsi 1.0 > tegra19x-mb1-pinmux-p3668-a01.cfg
Hi @carolyuu thanks for your replay,i see .
One question: after to execute pinmux_dt2cfg.py where I need to put the cfg file to be operational inside my Jetson?
@BARO
I use the TX2 and they go in ./Linux_for_Tegra/bootloader/t186ref/BCT/
