Hello,we use 2.5mm height AGX Xavier module as core board,and have two thermal conductive material problems :
(1) where is the heat source distribution area ?
(2) What is the recommended thermal conductivity material size?
Look forward to your reply!
Please refer to thermal DG and module datasheet for detail info.
https://developer.nvidia.com/embedded/dlc/jetson-agx-xavier-series-thermal-design-guide
https://developer.nvidia.com/jetson-agx-xavier-series-datasheet
We can not find thermal conductivity material size in these two documents.
What is the “thermal conductivity material size”? The size of TTP is in doc.
thermal conductivity material size:AGX Xavier 模组推荐导热材料尺寸多大?
Thanks a lot.
No such recommended size. Please refer to thermal DG for custom thermal solution design. For module itself, the TTP is fixed with module.
